Thread: Suggested replacement pump/filter for 18' Intex Ultra Frame?
    Jun 2013
    Green Bay, WI
    72
    Looking for a good but not to exspensive replacement pump for our new ultra frame. Need something that does a faster and better job of cycling that water.
    Thanks in advance!
    Doughboy 24' x 48" (AG), AQUA Tools Cartridge Filter, Frog System
    2004 Sundance Cameo SPA
    JamesT's Avatar
    Jun 2013
    Little Rock, Arkansas
    48
    Re: Suggested replacement pump/filter for 18' Intex Ultra Fr
    I have been very happy with the Intex 1600 sand filter. It seems to be a perfect fit for my 16 x 48 Intex pool. You might also consider the next step up from Intex. I believe they call that the 2650. The 1600 was around 140.00 out the door
    8 year old Intex 16 x 48 metal frame - Intex 1600 Pump with 14" sand filter - Intex Old Style SWG (ladder broke and poked huge hole in the side)
    New 18 x 48 Ultra frame Intex - Intex 2650 pump with sand filter - Intex Old Style SWG
    38,521
    Ideally we would recommend a sand filter at least 15". But, you have a short season so the 14" with the 1600 pumps should work just fine ... although the reports are that the 2650 pump (with 16" filter) does a much better job than some of the very undersized pumps with the cartridges. Likely either will work fine for you.
