Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: 1st Post, Burring an Intex 9' x 18'
    May 2013
    Florida
    21
    Hello, I am new to the site and to AGPs.
    I did a lot of research and couldn't find anyone who has put an 9' x 18' Intex Pool in the ground. So here is the process of me doing it. I don't have a lot of room in my back yard and didn't want the pool to be so high off the ground.
    Here are some of the questions I have so far:
    1. What Test Kit is recommended to check my water?
    2. The Pool is up and filled and the output valve is leaking ever so slightly at the twist connection seal, any suggestions?
    [attachment=2:2dshgewv]Pool001_opt.jpg[/attachment:2dshgewv]
    [attachment=1:2dshgewv]Pool002_opt.jpg[/attachment:2dshgewv]
    [attachment=0:2dshgewv]Pool003_opt.jpg[/attachment:2dshgewv]
    9 ft x 18 ft x 52 in Intex Ultra Frame
    1,200gal Intex Krystal Clear™ Sand Filter Pump
    Hayward Wide Mouth Skimmer MODEL SP1090WM
    May 2013
    Florida
    21
    Re: 1st Post, Burring an Intex 9' x 18'
    More Pics
    [attachment=2:1oqgedyh]Pool004_opt.jpg[/attachment:1oqgedyh]
    [attachment=1:1oqgedyh]Pool005_opt.jpg[/attachment:1oqgedyh]
    [attachment=0:1oqgedyh]Pool006_opt.jpg[/attachment:1oqgedyh]
    May 2013
    Florida
    21
    One more pic
    Finally leveling
    [attachment=0:2uehbw9y]Pool007_opt.jpg[/attachment:2uehbw9y]
    Jul 2012
    San Diego, CA
    96
    Wow, this is exciting to watch!! I can't wait to see it fully up! As for test kit, I have the TF100 and love it! Can't help much with the leak. I am constantly adjusting and fighting a leak at the inlet on my splash a round pool (similar to yours).
    NEW POOL : 9 x 18, 48" deep - Bestway brand, 1 HP Intex 3200 Pump/Sand Filter Combo, Wanda the Whale, Hayward through wall skimmer (still in box)
    OLD POOL 5,100 Gallons, 9 x 19 used Splash a Round, Intex SWG, 1.5 HP Hayward Power Flow LX pump, Pentair Clean and Clear 150 sq. ft. filter, hard plumbed, Wanda the Whale,
    Which side of the pool wall do you have the rubber gasket installed on?
    Should be on in inside.
    Love to see some pix of your finished set-up!
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    I want to see it filled too. That looks like a great job.. Been there..
    13k - Martinique 15x30 52"
    Sta-Rite crystal flo 22" sand filter & 1.5 spl rated
    Gorilla pad / waveless wall foam / foam cove
    Buried 2ft TF-100, TFPC
    May 2013
    Florida
    21
    I took the valve off last night and found the o-ring was was pinched, so put it back in the grove and no leaks now!!!!!
    I will take some pictures of the filled pool tonight.
    May 2013
    Florida
    21
    Here is a picture of the pool filled.
    This weekend is deck time if Tropical Storm Chantal doesn't interrupt.
    [attachment=0:2xhuwt73]Pool008_opt.jpg[/attachment:2xhuwt73]
    May 2013
    Florida
    21
    Here are my finished idea I sketched out.
    [attachment=2:1ujrr206]Pool01.JPG[/attachment:1ujrr206]
    [attachment=1:1ujrr206]Pool02.JPG[/attachment:1ujrr206]
    [attachment=0:1ujrr206]Pool03.JPG[/attachment:1ujrr206]
    Jun 2013
    Southeastern British Columbia
    79
    Awesomeness!! That is what we are doing as well!
    Looking very good. Can't wait to see more pictures
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    HacoboPablo's Avatar
    Jun 2013
    San Diego, CA
    63
    Wow, nice project you've got going, can't wait to see more of it!
    Intex AG 14'x42" Ultra Frame | 3357 Gal (3500 Gal from pool calc.)
    Intex 16" Sand Filter/2650 gph pump & Intex 54601EG SWG, Hayward SP1091LX thru-the-wall Skimmer, Intex Magnetic Pool Light, TF-100 test kit w/SpeedStir & Sample Sizer.
    Our first little Intex pool project...
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Make sure you leave a way to access the pool for repairs. Even if you have to dismantle part of the decking just ensure it is modular enough to to so.
    - Sent using Tapatalk
    Jun 2013
    79
    Did you dig this all by hand?? How long did the dig and leveling take? And how long to assemble the pool?
    May 2013
    Florida
    21
    My plans are to make the whole deck system modular. I will be starting on the deck this weekend if the thunderstorms will let me.
    Yes i dug it all by hand. I live in the Tampa Bay area in Florida, our dirt is mostly sand. The 1st 10"-12" is like top soil and then it is all sand after that. It took me 3 weekends to dig, build my retaining walls, level and set-up. I had help from a friend on one of those weekends. Pool set-up was the easiest it took me about 2 hours to do that. I designed my retaining wall so there was a lip at the 2' depth, I used that to level the ground. It worked out great. I surprised myself on how level everything was. I leveled my eye first and then went back with a 2x4 with a level attached to it. That took about 3 hours and it kicked my butt. That lip is also being used to support the legs. I didn't have to use concrete pavers.
    Jun 2012
    Mint Hill, NC
    2,589
    Awesome!
    xokeman's Avatar
    Jun 2013
    Memphis, TN
    72
    love it. this project looks great. i can't wait to see the final product....
    26k IG Vinyl, 2 HP single speed,24" Tagelus Sand, 1.5" pipe, 1 Main, 1 Skimmer, 2 jets, pool built 1983, new vinyl 2014, 36'x18', Deep End 8', The PoolCleaner 4X Suction.
    Pool Math #__# Pool School #__# Best Android App "Pool Pal" Track Your Levels!
    Jun 2013
    79
    how's it progressing??
    May 2013
    Florida
    21
    Very rainy weekend here, started on the frame in-between the storms. Not a very productive weekend.
    Jun 2013
    79
    We ended up taking the 13x 22 pool back and exchanging for the 9x 18 as well
    Any progress this week? We are at a standstill
  20. Back To Top    #20
    May 2013
    Florida
    21
    No process this week. Lots of rain and I had to have minor surgery. I am hoping to start it again on Wednesday.
