Results 1 to 11 of 11
Thread: 2 speed pump question
    I'm going to install a new 2 speed pentair pump (wfds-4) and it included the Hi/Lo toggle switch on the motor. My question, when swtich the pump speed, do i need to turn off the power first? or i can change the speed when the pump is running?
    - NY Albany ~27000 water
    - In ground Vinyl 18' X 40' X 8' Deep Curved Roman End
    - Pentiar TA 60 Sand Filter
    - Pentair WhisperFlo 1HP Energy Efficient Full-Rated 2-Speed
    - 250K BTU Nat/Elec. Heater
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: 2 speed pump question
    You can use the toggle only. Just curious, does toggle also have an off position?
    I didn't receive the pump yet. From the website it said the switch toggle for high and low speed. I want to know when we change the speed, do we stop the pump first? I can stop the pump from the timer.
    http://www.poolsupplyunlimited.com/best ... 1486/80332
    Donldson's Avatar
    NW Ohio
    2,917
    From low to high I don't turn mine off and it goes smoothly. From high to low I pause a beat in the off position to let the flow slow, then I switch to low. The hoses seem to hammer a bit if I don't do that. Not sure if it is an actual problem but it's no effort for me to pause a beat so I do.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2012
    western NY
    1,562
    Usually these switches have a center Off position. I switch mine from low-off-high and back again pretty quickly with no ill effects
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I've got just Hi/Low switch setting no problem switching.
    So you did switch the speed while the pump is running?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Yes, you can switch the speed while it is running. Most pools with controllers do this automatically.
    Mark
    38,521
    Switch with my Superflo does not have an OFF position ... I switch with the pump on with no problems ... now the ProLogic does the same.
    Jul 2011
    Monmouth County, New Jersey
    81
    Mine only has high and low. I have been shutting off to switch to low. Now that I don't have to shut everything down, I will probably switch to low more often.
    Built in October 2011, 16 x 26 x 20 L shaped vinyl IG steel wall pool, Hayward DE pro grid verticle filter 4800 pool, Hayward two speed superpump, 120,000 BTU Pentair Ultra Temp Heat Pump, Aqua Rite Salt system, 8' wide walk out steps, 2 skimmers, 4 returns, 2 main drains, 500 watt underwater light, intermatic mechanical timer
    Apr 2011
    Murrieta, CA
    2,360
    Runs 12 hours a day. All except about 3 minutes a day, when I check the pressure gauge to see if I need to clean the filter. It goes from low, to hi, back to low. No issues.
