Results 1 to 9 of 9
Thread: Question about Liquidator
    Aug 2011
    Southern California
    188
    I did a search and never found an answer. I'm thinking of adding the 8 gallon size, but not sure if my pool is too big as mentioned in another thread?
    What happens to the heavier chemical salts that remain in the bottom of the Liquidator tank? Do they build up over time? I've read a bit about them and a couple videos, yet no one says what happens to them other than they do not go into your pool.
    In most pools and spas that are sanitized with liquid chlorine (Sodium Hypochlorite), the liquid is poured directly into the water or pumped in using a chemical feed pump. This provides the chlorine necessary for sanitation, but it also introduces additional chemical salts that drive the pH up and contributes to the build up of dissolved solids...
    The heavier chemical salts remain in the bottom of the tank, while the chlorinated water is drawn into the pool for sanitation, because tmost of the potentially corrosive salts remain in the tank, the unit can be safely plumbed into the suction side of the pool equipment.
    22,542
    Re: Question about Liquidator
    I never saw any buildup on the bottom of mine, but any buildup would get cleaned out at the end of the season.
    I don't think there's nearly as much salts as the mfgs made out like there were.
    Aug 2010
    Dallas, TX
    4,052
    I never saw much of any buildup in mine either. Mine's one of those pools that's just too big to mess with using bottles of Clorox, even with a LQ though.
    Aug 2011
    Southern California
    188
    This is what I'm asking about. How is it getting cleaned out at the end of the season? Pumping it all back into the pool? I wouldn't think so based on the fact part of it's attraction is not putting those solids in to begin with. Unless that's not a real advantage as they claim.
    Quote Originally Posted by RobbieH
    I don't use Clorox because my pool store sells HASA SANI-CLOR (12.5%) for about $3 per gallon. Is the Liquidator only for Clorox bleach dispensing?
    Aug 2010
    Dallas, TX
    4,052
    Well, it's actually made to sell Hasa. But Clorox works in it too, just have to haul more of it.
    Aug 2011
    Southern California
    188
    Understandable. I thought maybe I had missed something that said it would only hold up to bleach type percentage levels.
    22,542
    Near the end of the season you just let it run out of bleach and fill with clear water and dump it out and rinse it. The stuff that's left in it won't hurt anything.
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    At the end of season, I take the hose off the exit float of the LQ and use it to drain almost all of the super chlorinated water into my pool. Then just rinse out the unit with water or add some vinegar or very diluted MA to remove any calcium buildup.
    David
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
    Aug 2010
    Dallas, TX
    4,052
    I had calcium in mine too, got pH and TA in check then added borates, and no more calcium (white stuff).
