Thread: Solar covers when to use
    HamburgerChef's Avatar
    Apr 2013
    Indianapolis Indiana
    100
    What is the consensus on solar covers. Obviously they are used at night if air temp is less than water temp. For a blue solar cover is it best to leave it on or off on a sunny day with 10mph winds. Pool temp is 77 air temp is forecast 85. Just trying to get warmer until i get the solar panels installed.
    13,500gal AGP Matrix 24'
    Pentair Sanddollar SD-80 75GPM filter, Pentair Dynamo 1HP 2 speed pump
    Polaris 65 pool cleaner
    (20'x30" solar heater to be installed)
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: Solar covers when to use
    You will read varying opinions but the majority say you gain more heat with the cover off as long as the sun is shining on it and it isn't crazy windy.
    Once you lose the sun cover it up
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
