Thread: Taking apart sand filter
    Jun 2012
    Cinnaminson NJ
    102
    I find the pressure on my gauge never rises. I have dirt and debris on pool floor within hours of vaccuming. I've also noticed when I vaccumm and backwash I don't see alot of dirty water being backwashed out. Could there be a broken lateral? I'm thinking about taking sand filter apart this Friday.
    Southern NJ, 1 HP Haward Pump, 16x 32 dimensions, 21,000 gallon vinyl liner inground pool, TF-100 test kit.
    Jun 2012
    Butler, PA
    336
    Re: Taking apart sand filter
    Purchase a new pressure gauge.
    Make sure hoses are attached properly, mine weren't and that presented a problem with filtering and backwash flows as well as "gunk" returning to the pool from the return.
    Service your multiport: with the power off & unplugged unscrew the screws & open it up. Look at your spider gasket make sure it is attached properly; if it is ~ clean and lube it. Lube the center spring that works the handle. If the spider gasket is "ratty" (unattached in places/ chunks of it missing), replace it. *Put everything back together tightening the screws evenly ~ not too much pressure ~ you want it evenly distributed between the screws.
    Open the tank: make sure sand is at proper level (I believe most recommend 2/3's full, but consult your manual)/ introduce a garden hose to the sand bed to free up any channeled sand. Close filter back up and go through a rinse cycle to seat the sand properly.
    I would try the above before removing the sand and checking laterals. Double-checking connections / replacing the gauge / servicing the multiport and deep cleaning sand bed might be all it takes to get things working correctly. If you remove the sand & check the laterals, but have problems in the other areas you'll still have issues. So I would do the easier exercises first & see if that fixes issues prior to removing the sand, just because removing the sand is a buggar.
    *edit for typos
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Jun 2012
    Cinnaminson NJ
    102
    I'll do just that on Friday. Thank you.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I have had good luck with these liquid-filled gauges for my pool filter as well as other applications: http://www.northerntool.com/shop/too...427+4294907752. A PSI range of 0-60 is best for most pool filters. Pay particular attention to mounting type and stem connection size to make sure you get one that fits your filter.
