Results 1 to 14 of 14
Thread: Pool water too hot!
    NY
    27
    Pool water too hot!
    My intex pool is too hot in the afternoon after a hot summer day. I have a cover that I place every night.
    Any ideas on how to cool the pool once it reachs 90?
    thanks
    Intex above ground Rect UltraFrame 12x24x52, 8500gal. Krystal Clear Sand Filter Pump 14". Intex SWG.
    HamburgerChef's Avatar
    Apr 2013
    Indianapolis Indiana
    100
    Re: Pool water too hot!
    Leave the cover off at night. That should lower the temperature.
    13,500gal AGP Matrix 24'
    Pentair Sanddollar SD-80 75GPM filter, Pentair Dynamo 1HP 2 speed pump
    Polaris 65 pool cleaner
    (20'x30" solar heater to be installed)
    Jun 2012
    Butler, PA
    336
    Use a fountain to aerate (a makeshift fountain from the return will work if you can make one of those, plenty of homemade pvc examples on the forum)
    Keep the cover off at night so the heat isn't held in when the air cools and the sun goes down.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Butterfly's Avatar
    South Carolina
    10,045
    ^^^ yep, leave off the cover and you could try running the pump at night to help w/cooling the water.
    What about some type of shade sails or maybe some well placed umbrellas?
    There is also the pool cooler. Use Google, upper right, for some ideas.
    You're done SLAMing when:
    Jun 2012
    western NY
    1,559
    Quote Originally Posted by marolir
    thanks
    I'll do a 50/50 swap with you, Just bring over a bunch and take some of my cooler water
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jul 2012
    Seymour, In
    49
    I am with everyone else with the cover off. I wish that was a problem here in Southern Indiana. Weather has been so bad, water is down to 75. We need the rain and cool weather to go away and bring back some sunshine.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    NY
    27
    I wish I could help you danpik and deeanron. But I tell you there is nothing worst than having a pool, temp at 95 and your pool at 90.
    tkx.
    Jun 2013
    Ohio
    53
    Find out where you can get a large chunk of ice and use it for a float!? Our public pool does that when it gets the hottest. No where near the diving area of course. LOL
    Intex Ultra Frame 18x48; Intex 56671EG 2,650-Gallon Sand Filter Pump; Intex Krystal Clear Saltwater System 15,000 Gallon
    NY
    27
    Hi everybody,
    I just want to let you know that I removed the cover and I built the fountain and the temperature is down 10 degrees to about 85.
    thanks,
    30,414
    Oct 2012
    Houston, TX
    186
    Sweet! I have an offset umbrella that shields a portion of it from the late afternoon sun and it is doing ok. Still... I'm going to build a fountain in a few weeks.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    Feb 2013
    Yukon, Oklahoma
    220
    Come about September and I bet you would be wishing your pool was 90 degrees!!
    Bob
    fyi
    if you have a menards in your area they have 12.5% chlorine on sale this week for $9 for 4 gallons.
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    Sep 2009
    Greentown, IN
    914
    I wish we too we could swap some water. We've hardly been in our pool this summer because of the cooler weather this year. Lucky to get to 80 degrees in the pool and often then it feels cold to us. Looking forward to some warmer weather and swimming over the weekend... fingers crossed!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
