Thread: New pool owner, please help!!
    Jul 2013
    Brampton, ON
    24
    Hi guys,
    I am a first time home owner which came with a pool. I opened my pool 2 days ago and I had to top off the water up to the skimmer. Today, the pool guy came, after the water was topped, and started the pump and vacuumed again and set up everything the left. Hour later, from the edge of the border, water started to come out!!!! Along with sand and foam!!!! I don't know what's happening and I'm freaking out. I have a mini pump which I used to drain out the wAter. Now, it looks like it stopped but I need to know what just happened. I didn't notice the water level go down, so I'm not sure if my pool has a leak. There was ALOT!!!! Of water coming out and foam. Please see the pic in the link. It doesn't have much water because I drained a lot, but you can see sand and foam. Please help!!
    https://www.dropbox.com/s/ffxprk1hydcw9 ... 0%20PM.jpg
    Inground Pool
    Jacuzzi Laser 225 Sand Filter
    Jacuzzi Pump
    22,553
    Re: New pool owner, please help!!
    Do you have a picture of how high the water was before you started pumping it off?
    What type filter do you have?
    Was the filter cleaned or backwashed?
    If so, where does the backwash hose go to?
    Jul 2013
    Brampton, ON
    24
    Hi there,
    I do not have a picture as I was freaking out and rushing to clear the water. I have a sand filter and there was no backwash done after the pool was opened. The backwash hose goes to my street and drains out there.
    More bad news,
    The water stopped coming out from that area, but I woke up this morning and notice the water level below the skimmer. Also, in the deep end of the pool, there is a lot of sand there.
    Please help
    Inground Pool
    Jacuzzi Pump
