Thread: Pentair Intellichlor IC40 - cheching remaining life
    Oct 2012
    Small Town Indiana
    28
    I have a Pentair Intellichlor IC (?I think it is the 40, but not sure). It is working, but I was trying to check the "life remaining" on the generator. I have only had the generator for 2 years (we are in our second year of running the pool). When I push and hold the MORE button, My lights at the bottom all run to the right, then there is nothing on. After a short time, several lights flash and then 3 lights are lit on the bottom. Initially I was thinking it has used 6,000 hours or 60% of it's life, which seems way too high. Now I am think that the lack of lights lit at the bottom initially is telling me that it has used less than 2,000 hours and it is resetting itself to an output of 60%? The explanation on Pentair's website doesn't really tell me specifically. To me, there are two times when lights flash and give a reading. ANY THOUGHTS?
    18,000 Gallons, 16 X 32, Sand Filter, IG, Vinyl Liner, SWCG, Built 2011, Opened April 2012, TF-100, speed stir,
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pentair Intellichlor IC40 - cheching remaining life
    No idea, sorry!
    Oct 2012
    Small Town Indiana
    28
    In case anyone else has the same problem. I did get a response from Pentair. They said that after the bottom bar scrolls to the right, the first set of lights is the percent of life used on the SWCG. As mine is "blank" with no lights, it has less than 20% or less than 2,000 hours of use.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Thanks for the update kjdo ...sounds like yours is in great shape!
