Thread: Sharing an idea, lower TA
    Aug 2010
    Lake Jackson, TX
    130
    I had a problem, my TA is too high. So I made a sprinkler that ran off a spare pump I had. That pump died so I was stuck wityh a way to drive the sprinkler. My solution is to run some pvc from the waste port to the sprinkler and set the multi-valve to rinse.
    The connections are all made with male/female threaded adapters so it can be broken down and stored when not in use.
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Sharing an idea, lower TA
    Looks great! Only problem I can see is your not filtering when you are doing that. It would be better if you could somehow tap into the return plumbing. What I do is take off an eyeball and put a temporary fitting (nipple usually in it's place).
