Results 1 to 16 of 16
Thread: Backwashing Filter - Step by Step Instruction Help
    Jun 2013
    Plymouth Meeting, PA
    29
    Hello -
    I am a new pool owner and was hoping I could obtain step by step instructions on how to backwash a filter.
    The pool has a Hayward DE Filter. The previous owner told me that the baseline pressure is 20. The gauge is up around 25, and I believe it is time to backwash as the previous owner also said he had not done it this season yet. If anyone could walk me through how to do the backwash, I would be greatly appreciative.
    25,000 gallons (in-ground plaster pool+spa)
    Hayward DE Filter, 1.5 hp pump, Polaris 3900 Sport Vacuum, Honeywell Heater
    TF-100 Test Kit, Using TroubleFree Method
    Getting the hang of pool ownership....
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Backwashing Filter - Step by Step Instruction Help
    What model is it? And do you have replacement DE or Cellulose standing by? Do you have a multiport valve (it's a rotary thing with about 6 positions, some don't) We can help if we know what we're working with.
    Also, you might check youtube. there are several how to videos, one may show your exact filter.
    22,553
    Either post a picture of the equipment or tell us what type backwash valve you have and we can probably walk you through it. We also need to know the size of the filter.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Here is the pool school article on filter maintenance:http://www.troublefreepool.com/pool-...pool%20filters
    38,524
    There is DE specific details in the "use and care of DE filters" article in the further reading section of Pool School.
    Jun 2013
    29
    Thank you for the quick responses, this forum is awesome. Below are a few pictures of the Filter. On the label there are model #'s listed but it does not appear that one of the models is checked, I could not find a model number etched anywhere on the filter.
    Richard320's Avatar
    Jan 2010
    19,071
    That's gonna be easy! http://www.hayward-pool.com/pdf/manuals ... DExx20.pdf is the manual. On page 4 there's a dimensioned drawing. Grab a tape measure and check your filter's height and compare it to the chart. That will give you the model number, from which you can determine the amount of DE you need.
    There's also directions in that manual on how to backwash. Just remember it never washes clean 100%, so only add 80% of what they specify, unless you feel bold and open the thing up to clean the grids perfectly.
    22,553
    Measure the height of the Filter and you can figure out which model you have.
    The 2420 is 32" tall
    The 3620 is 34" tall
    The 4820 is 40" tall
    Here is the list of steps for backwashing the filter.
    1. Hook up the backwash hose.
    2. Stop the pump.
    3. Press the multiport valve handle down and rotate it to the backwash position.
    4. Start the pump.
    5. Watch the small sight glass on the side of the multiport valve. The water flowing through it will start off clear and then become cloudy. Run the pump until the water in the sight glass becomes mostly clear.
    6. Stop the pump.
    7. Press the multiport valve handle down and rotate it to the filter position.
    8. Mix about 80% of a new fill of DE in a bucket of water to make a slurry.
    9. Start the pump and slowly pour the DE/water slurry into the skimmer.
    10. Enjoy your pool.
    Jun 2013
    29
    OK thanks for the information, it doesn't look to hard. The only outstanding question I have is which skimmer to dump the DE in?
    I have a skimmer pot that is right in front of the pump. I also have a skimmer basket right next to the pool. The previous owner told me he dumps the DE in the skimmer pot (the one right in front of the pump), but other people have told me you should never open that lid when the pump is on.
    Richard320's Avatar
    Jan 2010
    19,071
    Quote Originally Posted by kappadoce
    The skimmer by the pool's edge.
    Jun 2013
    29
    OK great! should i also set the pool suction valve (Jandy Valve) to 100% skimmer when doing this? Currently it is set to 50% main drain % 50% skimmer
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    If it were me, I'd take it apart and clean the grids completely. You are going to need to do that once a year at least anyways. Did the previous owner ever do that? It's not difficult, you don't have to take apart the grids, just get them out and soak them then rinse them with a hose.
    Here's what mine looked like when i took off the lid after backwashing.
    Yummy!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2013
    29
    the previous owner told me he cleaned the grids at the start of the season (april)
    22,553
    Dumping DE in the pump strainer basket isn't a good idea. It could clump and create a clog in the impeller.
    Jun 2013
    29
    should i set the pool suction to 100% strainer then?
    38,524
    Really should not make much difference if you use 100% SKIMMER or not.
    I like to put all the DE I need into a bucket, then fill the bucket with water and mix the DE into a slurry. Then just pour it slowly into the SKIMMER while the pump is running.
