Thread: HELP! Crack in plaster pool!
    Jul 2011
    North East
    135
    Hey all,
    About 1 hour ago, the shallow end of the pool ruptured causing a hole about 10" in diameter with hairline cracks shooting off from it.
    Obviously this is an issue. How do I go about fixing it? Is it going to cost an arm and a leg? Is it a do it yourself kinda deal or do I need someone to come in to fix it?
    sincerely,
    frustrated in the shallow end
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    22,550
    Re: HELP! Crack in plaster pool!
    Unfortunately it's not a DIY job. You need to call a PB.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    419
    This is a pretty significant failure in the concrete structure of your pool.
    How old is your pool? Just curious.
    It will first need to be drained and evaluated - as to why it failed.
    I would drill some core sample around the area and get tested to make sure it is not failing as well.
    Was it just a weak/ thin / or bad area in the gunite or is the entire concrete structure and or plaster failing??.
    If it is just one area it can be saw cut and new rebar and gunite can be applied - as long as the area is tied/ secured to the existing pool floor. And then is your plaster any good?
    You will need to re-plaster at least the area that failed (if you can fix the sink hole). If you do this you will have a different color plaster, but it is possible to be creative and blend in tiles or a tile sun for example to cover the area.
    A job like this is best left to a professional, unless you are highly skilled or have some friends in the trade to help you.
    Sorry to hear about this issue with your pool.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Jul 2011
    North East
    135
    Quote Originally Posted by blakeusa
    The pool is approximately 20 years old and we have owned it for a little two years. The previous owners had it re-plastered between 5-10 years ago, but I'd have to find the receipt to give a more specific date.
    It appears to my novice eyes the issue is more of a failing plaster issue rather than a structural but again thats from my novice perspective. I can see/feel the dark grey matter beneath the plaster (the gunite you speak of presumably) and the plaster chips away from the hole easily, kind of like peeling an egg.
    Either way, this sounds like an expensive repair and maybe the end of the pool season
    Is there anything I'm missing? Any recommendations for PB or repair companies in the Philadelphia area?
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    419
    Yes you need to find a qualified pool builder that at least can determine the cause and give you a quote to repair the pool if that is what you want to do.... and yes it will be expensive.
    My guess would be $4-6K if you have to repair the area and plaster the pool, then you need good quality water which could be another $1500 or more... but it is a pool and we love to spend money on our water pits.
    Sounds like the plaster failed and allowed water to eat away at the gunite/concrete structure. It still should not really have h appened as a sudden hole.... but it would need to be checked out...
    ColorQ Pro
    TF-100
