Results 1 to 11 of 11
Thread: Stuck skimmer plug
    Stuck skimmer plug
    We have a white skimmer plug stuck, we have tried everything to loosen it.....it is hard to get a grip on it in the small area in the skimmer. It is threaded with a square nut on top. We have tried a lug nut wrench with two 10" extenders, but we started stripping the lug nut. Any suggestions?
    Jun 2012
    Louisville, KY
    266
    Re: stuck winterizing plugs
    There are sockets meant to grab onto a stuck/striped nut.
    Or you try a "basin wrench" used for getting behind sink basins.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Thank you....I will see if the hubby has either of those tools.....or yet another trip to the hardware store!
    Feb 2008
    Denton, TX
    5,061
    Re: Stuck skimmer plug
    Welcome to TFP CinDog!
    I went ahead and split your topic off on it's own. Please start your own thread when posting a new issue. Thanks!
    Jun 2012
    Louisville, KY
    266
    Also are you sure that plug is supposed to come out? Many skimmers have two holes. One is permanently plugged which is likely what you're dealing with.
    Is there another hole to get water flowing and is this your first year with the pool? My question mainly is are you sure you can remove that from the skimmer?
    Thanks but yes it needs to be removed. We don't close our pool, but we have opened it for the last 20 years and this is the first time we have had this problem.
    Jun 2012
    Louisville, KY
    266
    Quote Originally Posted by CinDog
    Gotcha. Just had to get the obvious out of the way.
    You can't grab hold of the nut and get some torque on it. The special nut removal socket or basin wrench will allow you to get it.
    The Basin Wrench did the trick, thanks to everyone who took the time to respond to my thread.
    Jun 2012
    Louisville, KY
    266
    Now come on now! I need more props for that!
    Just kidding, if it wasn't for 10 work hours over a week fighting how to unscrew a sink basin supply lines into the handles, bare and raw knuckles, that there was no way in **** I could get a bite on I wouldn't even know a Basin Wrench existed.
    Plumbers are well worth their pay, as are their tools.
    Very happy you got it.
    Aug 2014
    Clifton/VA
    1
    I'm having the same problem, going to Home Depot later to pick up a basin wrench! Thank you for posting!!
    Apr 2018
    Toronto/ ontario
    1
    I have the same problem. This is my first time of opening the pool though. Note sure if it’s a permanent plug or it has to be removed. I even tried opening it with feherguard wrench and wasn’t successful to open it.
    any help is appreciated
