Thread: Connecting 2 6ft flexible hoses
    I have just built a 15x24 AGP with a Hayward 1HP Extreme Cartridge filter. How can I connect 2 flexible 6ft hoses for my pump and filter? After my deck was built to wifey's measurements, I need at least 10 ft to connect my pump and filter to the skimmer and return. My local pool store sold me flexible PVC, but when I went to the hardware store they told my flexible PVC is too rigid to clamp. I purchased 2 additional 6ft flexible hoses with a pool hose connector but the connector seems to be flimsy. Can these be clamped? HELP!!!! Kids dying to get wet!
    THANKS!!!!
    15x24 AGP Hayward 1 HP Extreme Cartridge Filter
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Connecting 2 6ft flexible hoses
    Flex PVC uses normal PVC glue fittings. Your hardware store is correct, clamps will not work with it.
    Regular slip fittings, or threaded to slip adapters are commonly available.
    Mar 2011
    Grand Rapids, Michigan
    279
    winterpoolsupplies.com sells 12'/ 1.5" hoses for 17.99, if you decide to stay with flex hoses. I buy 9 and 6 ft hoses from there. It's the best price I could find. I didn't like the idea of using a hose connecter if I didn't have to.
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
