Thread: another vacation question
    Sep 2011
    Miami Beach, FL
    125
    So my pools looks great, sparkly water....just completed shock process and upgraded my filter in the last couple of weeks. I have been tweaking my levels for the last weeks. Pretty stable now.
    FC 12
    CC 0
    CYA 60-70
    TA 70
    pH 7.5
    CH 300
    Bor 40
    Salt 3100
    50% on the SWG for 7 hours
    I have three days left to play with it before vacation.
    Leave it be? Try to tweak it more?
    I would really like to run it more like 6 hours, but want to make sure its stable....
    Thanks as always
    32000 gallon, inground, fiberglass, Aqua-Rite SWG, Pentair 420 sqft cartridge filter (Installed-ya baby), Hayward Super II pump 1.5 hp, 144k BTU heat pump, Dolphin Dx5 Plus, and a good test kit from Duraleigh!
    Feb 2008
    Denton, TX
    5,061
    Re: another vacation question
    Right now, you look ok. I don't see much reason to try anything different until you get back home really.
    Sep 2011
    Miami Beach, FL
    125
    Got home late yesterday....I was gone for 10 days
    My plan was to add two 121 oz 8.25 percent jugs right before leaving.
    We had a ridiculous amount of rain at my house and the pool likely over flowed quite a bit.
    I had a moderate amount of debris to clean out but my
    FC=8
    CYA=60
    but someone stole my water after I ran my robot!
    Thanks again TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Yes they did!
    Things worked out great!
    You're done SLAMing when:
