Thread: Staining of hands while testing and adding chemicals.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Quick question regarding some staining on my hand while testing and adding chemicals. Seems like every time i run a full set of tests using my TF-100 test kit (inc. Salt drop test) and then add the required chemicals, i get staining on my hands. Not sure what combination of testing or adding of bleach / muriatic acid that is causing the staining. I guess I should just wear gloves, but I was curious if I am the only one with purple hands and a sparkling pool.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Re: Staining of hands while testing and adding chemicals.
    That is almost certainly from the salt test. None of the others are know to cause staining like that.
    Feb 2008
    Denton, TX
    5,061
    Not sure what the reagent in the salt test is, but that looks like silver chloride staining.
    Sunny SoCal
    591
    I think you guys are right. Seems to always happen right after I test the salt level.
    The reagent in question is Silver nitrate, used in the test to measure sodium chloride.
