Thread: **** flows out of jets when pump is turned on
    Every time I backwash the pool when I turn on the pump **** flows out of the jets momentarily.
    16x32 inground vinyl pool
    Hayward sand filter
    Hayward 2 hp super pump
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: **** flows out of jets when pump is turned on
    are you rinsing after your backwash? That could be where the crud is coming from.
    No I didn't know you needed to do that! How long should I run the rinse?
    Hayward sand filter
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Rinse until the sight glass is clear. This could take 10 to 30 seconds. You are shutting off the pump before moving the lever, right?
    Yes I turn off the pump whenever I need to move the selector on the filter
    Hayward sand filter
