Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Partial drain to lower CYA- Now what?
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Have been reading the posts on many forums and really appreciate the knowledge being shared. It became obvious to me the only way I was going to get back to a "trouble free pool" was by draining off about 3/4 of my water, which I am doing now. My question is when I refill what steps should I take. I do have the Taylor test kit referenced throughout.
    Shasta 10,500 gallon play pool/spa, pebble tech finish (10/12), in floor cleaning, 2' free-fall, deck jets, Hayward 2hp SP3400VSP pump, Jandy 8 cartridge filter, LX heater and AquaLink Sunny Phoenix, AZ
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Partial drain to lower CYA- Now what?
    Once its filled back up you have to get your chemistry in balance. You should just need chlorine and muratic acid. Hopefully your CYA is close to your target range once you have refilled. Test your water and reference the pool calculator to see what you need to add. You will need to decide how you are going to chlorinate your pool from here on out. If you follow the advice here you will use bleach/liquid chlorine. If you use pucks you will be in the same situation later down the road. Read pool school so you can understand whats going on with your pool and start enjoying your pool again.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Jun 2012
    Howell, NJ
    977
    Going on what Shane said, you will definitely need chlorine. However, you may not need muriatic acid. It all depends on the pH of your fill water. For example, my fill water has a low pH (probably below 6). So for me, I need Borax. Yu may have high pH fill water, so you may need muriatic acid. So fill the pool up, let the new water mix, and then post test results.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2013
    Fallsburg, NY
    258
    Which taylor kit did you get? Most don't have the FAS-DPD test eg. K-2005 which is probably the most important one.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Refilled the pool and added 1 gal liq chlorine while filling (12.5%). Here is this mornings test results; FC=7, CC=<.5, PH=8, TA=140, CH=190, CYA=50
    My water is clear but not sparkling. What should I do and in what order?
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Partial drain to lower CYA- New test results
    Topics merged. Lets keep everything here. Bama
    22,551
    Re: Partial drain to lower CYA- New test results
    Lower the pH to about 7.2 first.
    I'd suggest running an OCLT. I know it's a new fill but that just rules out anything organic.
    I'd also run the filter 24 hours a day until it's sparkling.
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Thanks Dave, I'll adjust the PH and run the test tonight.
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Dumb question= Did you mean to shock and run OCLT or just run OCLT?
    Jun 2012
    Howell, NJ
    977
    I know most people run the pool up to shock level when they do the OCLT, but I am not sure if that is necessary.
    John
    22,551
    I would raise the FC to at least the top of the recommended level for your CYA and then run it.
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Added 16 oz muriatic acid, new PH=7.8; adding 12oz more. What is the preferred method of adding acid to the water?
    Smykowski's Avatar
    Sep 2011
    3,065
    Pour very slowly in front of a return so it mixes immediately.
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    I read somewhere on the site that the pool calculator was available to download to use when offline. Can't find any reference on how to do it. Can anyone help?
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    OK, got PH to 7.5. Total FC loss yesterday due to sunlight and light bather load was 4.5ppm. Raised FC to 6 and ran OTCL. This morning's reading is 5ppm, 0-CC. Yesterday it was 106 during the day and the overnight temp never went below 85. Am I good to go? EDIT Just checked my PH, up to 7.8 O'nite! Is that typical?
    22,551
    Technically you passed, but if it were me, I'd run it again tonight just to make absolutely sure.
    Go ahead and add some acid to lower the pH.
    Jun 2012
    Howell, NJ
    977
    What kind of bleach did you use? Some generic bleaches have excess lye, which will tend to raise your pH some.
    John
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    To use the pool calculator just save the page as an HTML on your harddrive. I'm using firefox, so to do that I go to File, Save Page As...
    Then when I want to use it offline I go to File, Open File... and open the file I saved.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
  20. Back To Top    #20
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Thanks, I will run it again tonight; cheap insurance! Already dropped PH to 7.2. As for the bleach, I am using 12.5% chlorine from wholesale pool supplier.
