Results 1 to 9 of 9
Thread: SWG question
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    SWG question
    Sorry if this is a basic question.
    Have a ig pool build starting next month. I'm looking to do the BBB method and considering a SWG.
    PB uses haywood products. My question is if going BBB, do I need a basic haywood SWG or should I look into the pro or pro plus units which measure ph and orp.
    Pool will be 16x36 3.5' to 8' deep.
    25k IG vinyl SWG Haywood 4830de 1.5hp TF-100
    Re: SWG question
    The basic unit is a good choice. I think that the other options can be counterproductive.
    Support the site
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: SWG question
    Any way you go , Hayward makes good products !!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Re: SWG question
    Thank guys. And from what I read, go with the 40,000 gal cell as it will last longer and not work as hard?
    Re: SWG question
    Yep, it lasts longer and it also gives you some extra capacity for "special occasions".
    Re: SWG question
    Although I don't think that automating pH and ORP are helpful. I do think that automation can be a good choice depending on your budget and options. You might want to consider the ProLogic or the AquaPlus.
    http://www.hayward-pool.com/ctg/In-Grou ... /index.htm
    Support the site
    Jun 2013
    Mountain House, CA
    4
    Re: SWG question
    Quote Originally Posted by JamesW
    We just had our pool built (finished 6/7/13) and the PB installed the basic Hayward automation and SWG. Now we have figured out that we want more control over the system (and the ability to turn things off/on using our cell phones) so we are looking at upgrading to either the ProLogic or AquaPlus. I would definitely investigate thoroughly first, so you aren't changing things only a month after your pool build!
    Carley
    15K gal IG Pebble Sheen pool, Hayward Ecostar VS 2.0 HP pump
    Hayward Swimclear Cartridge filter C4030, 150 GPM
    spa/SWG/ECommand 4 finished 6/7/13
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Re: SWG question
    Still trying to decide. Basic pool electrical panel, 8 breaker slots with 1 timer is $200. I plan to go salt water and looks like a basic aqua rite with cell is $1100.
    Pro logic panel with salt cell will run about $1400.
    So, if I priced it out correctly, it's about a $100 difference to have future options available, and connectivity.
    Does this sound correct?
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Re: SWG question
    Ended up buying a pro logic and 40k gal salt cell. Thank you all for the input!
