intelliflo 220 wiring to an easytouch 8
Jun 8, 2013
46
I have the easytouch 8 and the intelliflo vs. Can the pump's 220 be wired into the load center as an available 20 amp breaker or should it run back to the main panel as a stand alone run.
IMPORTANT: When connecting the pump to an automation system (IntelliTouch, EasyTouch,
SunTouch and IntelliComm), continuous power must be supplied to the pump by connecting it
directly to the circuit breaker. When using an automation system, be sure that no other lights
or appliances are on the same circuit.
Does this mean a dedicated breaker in the load center? I am pretty sure that this is the purpose of the 150 amp capacity but want to make sure.
