Thread: Best Place to Start
    Jun 2013
    North Western NC
    12
    Best Place to Start
    Used the 3" pucks last year and had the water tested at the local pool store. Found this website and after reading I realized there is a better way. Bought a Taylor K-2006 and wanting to know where to go from here:
    FC - 9.5
    CC - 0
    pH - 7.0
    TA - 30
    CH - 40
    CYA - 65
    I found some visible algae about 4 days ago and shocked the pool with several pounds of calcium hypochlorite that I had left over from last year. This was before I read the shocking instructions listed on this site. The FC level has dropped from 15 to 9.5 in 3 days. The water is currently clear and I want to become a BBB convert but wondering where to best start. Thanks in advance for your advice.
    20k gal, IG vinyl, 1 HP Hayward pump, Hayward 200# sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Best Place to Start
    Welcome!
    Adjust pH and TA with Borax and Baking Soda. http://www.poolcalculator.com/ can crunch the numbers for you.
