Results 1 to 9 of 9
Thread: Help Please!
    Help Please!
    My wife is not happy with the cloudy water and let's me know daily! A little background: went on vacation for a week and had a friend watch the pool, when we got home it looked as bad as it ever has, green pond looking. Dumped bleach in and it began to clear up. Now I am 2 weeks in and here are my numbers to my cloudy pool:
    FC 7
    CYA 70
    TA 80
    PH 7.6
    Salt 3100
    I am running the pump about 8 to 9 hours and can't clear it up. Help save my marriage! Ha!
    23513 Gal. IG, Vinyl
    24" 300# Sand Filter
    1.5 HP Superpump
    P4 + Aqualogic, SWG (T-15)
    Benton, Arkansas
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Help Please!
    You likely have just not kept the FC high enough for long enough. Especially with CYA 70. That's good for having a SWG, but it takes more FC to do the job. You need to complete a shock process until all criteria are met. If you read "how to shock your pool: It will tell you about all that. It would also be good to see your CH and CC numbers as well.
    Essential Links:
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Help Please!
    Brushpup is dead on. You need to shock, and right now you're spinning your wheels because that FC is too low. Off to Pool School!
    Jun 2012
    Howell, NJ
    977
    Re: Help Please!
    What kind of test kit do you have? To properly follow the shock process, yo will need the TF-100 or K-206 which is linked to in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Re: Help Please!
    Thanks All, that is what I was thinking but needed to hear it from someone else. I do have a Taylor K 2006 test kit.
    1.5 HP Superpump
    Benton, Arkansas
    Re: Help Please!
    So based on the shock procedure, i am supposed to hit a FC of 28, am I reading that correctly? I guess I need some more bleach about 6 gallons or so? How is that going to affect the CYA, PH, and TA?
    1.5 HP Superpump
    Benton, Arkansas
    Jun 2012
    Howell, NJ
    977
    Re: Help Please!
    Bleach won't affect CYA or TA. It will TEMPORARILY raise the pH of the pool, but as it is consumed, the pH will go down. So effectively it is pH neutral.
    John
    Donldson's Avatar
    NW Ohio
    2,896
    Re: Help Please!
    Quote Originally Posted by Conehead
    Not hit, maintain an FC of 28 til the process is done. If you have active algae you will need more than 6 gallons. It will not affect CYA or TA, pH will probably rise a bit but you can't accurately test while shocking.
    After you get it under control you will just need patience while the dead algae filters out. Run it non-stop til it is cleared. Been there, the wait that seems to never end, but it will clear up if done right.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Help Please!
    No one can say how much bleach it will end up using, but I'd stop tomorrow and pick up at least 4 more bottles if it were me.
    Essential Links:
