Thread: Intellichlor chlorine generator IC40
    I'm having trouble increasing the output of my chlorine generator from 20%. All the lights are green and it appears to be working. I've been taking water samples on a regular basis to my local pool supply, and I have been able to keep my pools water chemically in balance. When I first started this a few weeks ago I had 0 chlorine in the pool which through shocking it the chlorine level got up to a 10.
    Now a week has pasted since it was a 10 and as of yesterday it is a 5.
    I was asked to clean and inspect the generator which I did, and found it not to be dirty or scaled up. I still can not get the generator output past 20%.
    Any ideas ??
    Thanks
    Intex Ultra Frame 18'x48" (AG), 6,423 gallons, stock 1500gph pump/filter, installation started 6/24/2013
    Re: Intellichlor chlorine generator IC40
    Welcome to TFP!
    If you have an automation system, the controls for the SWG are on the automation system and the controls on the SWG it's self will be locked out.
    Thank you for the quick reply. Is there a way for me to change this setting ? I believe its obvious from my sample results that it has to be increased.
    Again Thanks for any help !
    Yes, you should be able to change the percentage setting. How you do that is different if you have an automation system or not. If you have an automation system you use the controls on the automation system, if you don't have an automation system you use the controls on the SWG cell.
    If you want more specific help, you need to give us more information.
    Thanks for your help, I was finally successful in adjusting the output. I set it at 60% and will leave my pool pump run 24hrs for the next week to see what happens to the chlorine level.
    Can you recommend a good home test kit that might cut down my trips to the pool supply co.
    10K gal, ig,gunite,Pentair EasyTouch,Intellichlor chlorine generator
    The TF100 from TFTestKits.net is my favorite.
