Results 1 to 9 of 9
Thread: TA-PH-CH testing sequence questions
    sorry if this seems like a repeat or is listed elsewhere
    PH = 7.3
    TA = 70
    CH = 200
    CYA = 40
    1. should I bring the TA up to 90/100 first...then test everything again?
    or also bring up the CH to 250 at the same time?
    2. I will wait to test PH again, but to raise PH what is best chemical to use (I have some Leslies soda ash a couple years old) or should I get some borax or something else?
    wondering if there is a preferred sequence here...or if I am splitting hairs trying to get more optimal levels?
    thx
    24K gal, plaster, concrete decking, cantelivered coping, 20 years old, raised attached stone spa - 1 1/2 HP purex triton pump, 3 yr old 48 sq ft Pentair DE filter with multiport, Polaris 380 w/pump, 2 yr old Pentair mastertemp 400k heater - live in southeastern PA outside phila.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: TA-PH-CH testing sequence questions
    I'd just go swimming, myself. CSI is still in the safe zone. You're in the enviable position where you can chlorinate with Cal-hypo, so that's what I'd do if I was you. Everything but CH is good.
    Soda Ash is great for raising pH, and since you already have it, use it up! But not right now - pH is fine.
    30,408
    +1 what richard320 said.
    great answers...thanks....don't want to overthink things......thanks again
    should I use di/tri chlor pucks that I have on hand or go buy some cal-hypo ----have lots of chlorox around too..
    30,408
    Please read "How to chlorinate your Pool" up in Pool School.
    I know how to chlorinate
    Referring to the cal hypo comment specifically
    Jun 2012
    Howell, NJ
    977
    Di and trichlor add CYA, which you don't want. Cal hypo adds CH, which, in your case, you do want.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by jp4120
    Cal hypo, for the reasons stated below. But I see no reason to make a special trip to buy Cal-hypo if you have Clorox on hand. Just next time you need to resupply, buy the cal hypo instead of more Clorox.
    But don't throw the trichlor pucks away, they're slow-dissolving, so they're great for vacations. They will lower pH , so the soda ash you have can counteract them.
