Results 1 to 8 of 8
Thread: Test results test results getting better now what
    Oct 2012
    Haydenville, MA
    13
    We have recently opened our pool and have been battling algae for about aweek- it had been growing for a lot longer than that. I have been keeping the shock level high- today it is very high. Yesterday, I backwashed 6 times and broke the filter down once. The filter is doing it's job but we still can't see the bottom.
    Here are my numbers:
    FC 26
    CC 1.5
    TC 27.5
    pH 7.2
    TA 60
    CH 200
    CYA 50
    Any suggestions for next steps would be great. I am thinking possible changes would be calcium, baking soda for TA and Borax. Should I wait or address these now?
    Thanks _BB
    25000 gals, IG vinyl liner, Hayward sand filter,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Test results test results getting better now what
    Stay the course. It's still cloudy and you still have over .5 CC.
    Algae is like unwanted weight. You can grow it a lot faster than you can get rid of it.
    30,421
    Keep your chlorine right up there. That's the whole idea in the shock Process.
    read "How to Shock Your Pool" up in Pool School. Follow that article to the letter and your pool will clear.
    Everything you post seems perfectly normal and you have a good grasp of what is happening in your pool. Keeping your chlorine up high constantly is the key to success.
    Disregard your other parameters until your pool is crystal clear......it will be soon if you hold your chlorine up high
    Did I mention to keep your chlorine up?
    Oct 2012
    Haydenville, MA
    13
    Todays FC
    9 AM 26-----pretty high
    1 PM 22-----dropping
    9 PM 18------do I add bleach now or wait til morning?
    Target shock FC given CYA of 50 is 19.6
    It is getting clearer--hooray!!
    Jun 2012
    Butler, PA
    336
    At night, I personally go a smidge above target shock level, just in case I am not interpreting my CYA level correctly.
    I also like to make sure prior to bedtime I am dosed properly because with no sunshine the chlorine can really get the job done.
    In the morning I retest everything, I then dose it up (if necessary) and give a little more of a cushion than I do at night time because when I am at work I am not able to test and the sun does cut into the action and breaks the chlorine down quicker.
    Others might hop on and share how they handle it. But for me target is the minimum I try to be at, at all times throughout the shock process. And I did note how much I was losing during the day & weather conditions so I could better predict what I needed during the day while I was at work to make sure I maintained levels 24 hours a day. Night time because of the lack of sun it's a bit easier, but it's still very important to keep at target level for you CYA.
    It's a great feeling to see the progress, kind of like a rush when things start working. Congrats on your accomplishments to date and keep on keepin on
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by bevbull
    Todays FC
    Do it now - then there will be no loss to sunlight. 100% of it can work on algae.
    Oct 2012
    Haydenville, MA
    13
    Just checking in after 6 days of keeping the shock level up, backwashing, breaking filter down 2x, vacuuming now that I can see I am just wondering if I am doing ok.
    It has been sunny and hot so yesterday I added CYA to get back in range. Here are my numbers---I must admit I was hoping for a good Overnight FC test but maybe tonight.
    FC 14 it was 18 at dusk
    CC .5
    TC14.5
    CYA 45
    will be adding cholrine this morning to get my levels up and see how we fare this evening...a long work day today.
    Have a good one.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Keep at it. Your doing fine and making progress.
