Thread: what time of day should i hit target chlorine levels?
    if my target FC level is 4, when should i hit that? morning, night, or immediately before swimmers enter the pool?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: what time of day should i hit target chlorine levels?
    It doesn't matter, as long as it's pretty much the same time every day. The key is that you never slip below the minimum at any point between doses. If minimum FC for your CYA is 4, and you target 6 and the next day it's at 3.5, you need to target 6.5 the next day so it never drops below the minimum. And sadly, you can't just double up and skip a day, because it's not a fixed PPM per day; the loss is a percentage of the starting, so you lose more at higher FC levels.
