Thread: Too much salt
    Jun 2013
    Minnesota
    36
    Too much salt
    So I've been using salt test strips and I thought my levels were good but I recently got the Taylor salt test kit and that says my salt is 2x what it should be!
    The question is, can I just leave it and wait for my SWG to bring the level down? Or do I need to dump a bunch of water and add fresh?
    --- Pool Status - Ice Cube
    18'x9'x52" Intex Rectangular Pool with Krystal Clear 2560gpm Sand Pump and Krystal Clear Salt Water System
    Hayward Skimmer with (2) 1 1/2" Hayward Returns
    16mil Klear Choice Solar Blanket
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Too much salt
    The salt level will only change by splashout or backwashing.
    It seems to me that if the SWG isn't displaying high salt codes, it's happy and working. I'd leave it alone.
    Jun 2013
    Minnesota
    36
    Re: Too much salt
    I haven't turned on the swg yet, was waiting to ensure CYA was ok. I guess I can try turning it on and see what it does.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Too much salt
    Quote Originally Posted by blacknoir
    Did you add the amount of salt that would result in levels that high? Could you blame the results on either testing error or expired strips? How much salt have you added up to this point?
    If you are truly at 6000+ ppm then your SWG should throw a "92" and alarm. I'm leery....but we'll know soon enough.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
