Results 1 to 15 of 15
Thread: algae
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    algae
    New pool owner and I have not yet purchased a good test kit. I only have a cheap chlorine and ph tester (using red and yellow drops) and I have those 4 in one test strips. Had some early signs of algae that was sprawling across the floor and a bit up the sides. Pool store had me put 15 litres of 10.3% liquid chlorine to shock the pool and attack algae.. According to their water test CYA was 81ppm in an 83000 litre pool. The water was a bit cloudy. I vacuumed and scrubbed until there were no traces of algae. I added the chlorine Friday night. Saturday morning to my surprise the water was crystal clear. There were a few pockets of clumped algae as opposed to sprawling along the floor and walls. I assumed it was dead algae. I vacuumed again (to waste not through filter) and all seems fine. Added water as vacuuming to waste took a lot of water out of the pool.
    This evening I notice a much slower growth of the same brown/orange along two vinyl seems along the bottom. I vacuumed it up. A few hours later Small traces are back at the seems.
    I have very basic testing available but the strips tells me FC is through the roof and the drops testers show neon yellow. I cant get to the store for another test (theirs is still better than what I have). Should I shock again or will the high chlorine keep attacking the algae? I am nervous of adding more chlorine. Will it hurt my liner and/or equipment.
    16' x 32' IG, vinyl, 80k litre (21k gal), "lazy L" (kidney like at deep, squared off at shallow) shallow 3', deep 8', Hayward sand filter 300 lbs, 20gal/min Mod S-244T, Pentair Superflow VS 1.5 HP Model 342001, Raypak Heater 266K BTU Mod P-R266A-EN-C, 2 returns, 1 skimmer, 1 main drain, diving board, Southern Ontario (Canada) climate.
    Jun 2013
    SpringHill FL
    415
    Re: algae
    A good test kit is essential to doing anything to your water......but if you dilute your pool sample with tap water a 50:50 mix and do your drop test for chlorine you may get a readable result which you then double for a almost accurate reading........I cant stress enough how important a quality test kit is
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jun 2012
    Howell, NJ
    977
    Re: algae
    Test strips and pool stores are about equally worthless. Since you mentioned liters, I assume you are in Canada? Someone who lives there will be able to give you advice on how to get a test kit.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: algae
    From my own research (which I hunted down here using search) Blinding yellow is about 10. School bus/construction equipment yellow is about 12-13. Hunter orange is around 18, up around 25 it starts to look pumpkin orange. I never went any higher than that, but it's been reliably reported that it eventually will turn brown if you get high enough.
    So you're probably still not at shock level for 81 CYA.
    I'd advise you to fill out your signature - upper left User Control Panel>Profile>Edit Signature soon. You're going to get nagged to death to get the proper test kit and there's only one source in Canuckistan for it.
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Re: algae
    Thanks all. Cannot get a test kit quick enough. I do realize from all the posts throughout this forum how important it is. But not easy to get here for some reason at least at a reasonable price. Anyways I wad just wondering if it were necessary to shock every day to combat the algae or if that would harm my pool.
    Cheers
    Richard320's Avatar
    Jan 2010
    19,031
    Re: algae
    Quote Originally Posted by shane4
    Cheers
    Off to Pool School with you!
    Shock is a process, not a product, and not a one-time thing. To totally eradicate the algae will take anywhere from several days to several weeks at shock level. The good news is, once you get rid of it for keeps, if you commit to maintaining the pool properly, you may never have to do it again.
    A little inspiration:
    first-time-shocking-with-bleach-t45074.html
    pretty-black-pool-t58442.html
    first-time-pool-owner-t61565.html
    a-little-encouragement-for-those-with-algae-and-new-to-bbb-t57137.html
    frog-filled-green-swamp-to-oasis-work-in-progress-t48213-20.html be sure to look at page 2
    before-and-after-t36785.html
    a-final-picture-set-of-how-well-the-bbb-method-works-t33199.html
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Re: algae
    Been trying to go over the entire pool school as well as other threads. So much to review, so much to learn, so many questions to ask.
    Thanks for the direct links Richard320, I am off to shock and continue reading
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Re: algae
    Just to give an image of what I am dealing with here are pictures of these "clumps". My water is crystal clear.
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Re: algae
    Rules section did not mention picture sizes (unless I missed it). Are the previous pics ok size?
    30,424
    Re: algae
    Shane4,
    Carefully and slowly peek out the window.....the TFP Forum SWAT Team should have your house completely surrounded by now
    (The pictures are just fine and you are an excellent member for reading the rules. Thank you.)
    PS - Throw a six pack out the front door...our SWAT team is easily diverted.
    Almost forgot....the pics definitely look like small piles of dead algae. Do they brush away easily?
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Re: algae
    .........shhhh, some one is in the bushes..........
    It looks like dead algae????? I assumed because of the green colour it was alive and well. As for removal, it sucks right up with the vacuum in one pass.
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Re: algae
    I think i got it beat! Never lost the clear water except for a day and no more greeny clumps
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: algae
    Good job !!!
    Jeff
    Jun 2013
    SpringHill FL
    415
    Re: algae
    Looks good
    Nathan
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Re: algae
    Thanks for the help!
    Only thing concerning me is I seem to still need to vacuum up what looks like small pockets of dead algae. How long will that continue?
