Thread: Need to repair plaster
    Topics merged, please don't double post. Bama
    the plaster has popped up on top of one of the steps. It's about the size of a coffee cup.
    Can I repair this myself? If so, what product do you recommend.
    Intex Ultra Frame 16x48
    5300 Gallons-3/4hp Doheny's Pump-16" Hayward Sand Filter-Hayward Skimmer and return.
    Our pool is Gunite....The plaster has popped up on top of one of the steps. It's about the size of a coffee cup. It really looks like it's just a slurry coat over white plaster..very thin, flaking material.
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    Re: Need to repair plaster
    Is your finish on the pool white plaster? I just used a product called Perma-Pool-Patch to reset a bunch of tiles that had fallen off our pool. It is really for repairing the plaster, but the pool store also recommended it for resetting tiles and even as a white grout. It was fairly easy to use, I used a plastic cup with a plastic spoon and plastic knife, and could use about three spoonfuls of powder to a slight bit of water, mix, and apply to 3-4 tiles at a time before it became too set up to use. It sets up FAST.
    It can be used underwater, too, it needs to be mixed thicker, more like a putty, rolled in your hand like play-doh. I reset about 9 tiles underwater on the steps and it worked great as long as I had it mixed thickly - when it was too thin, the tiles popped off. However, I couldn't reset the wall tiles underwater, they kept falling off and I may not have been getting the consistency correct. I eventually drained the water to just below the tiles and set them all. It's only been about four days, but they seem rock solid right now.
    Good luck!
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
    Hi MiaOKc....Yes the plaster is white. The material that is lifting & popping out looks like 'egg shell' quality. The underlaying plaster is fine & smooth. That's why I mentioned it looks like a slurry coat 'over' plaster. The place is underwater so since it is the top step we can drain down to that place easily. It's on the flat center in the middle of the step, right where you would put your foot to enter the pool. No tiles involved. I would like instructions from someone about how to patch this thin coating that is over perfectly good plaster. Some videos talk about sanding out the section. It's not that big of a problem like a crack would be. We don't know which product would be best we have looked at ArmorGuard Expoxy coating, EZ Patch 1 (Acrylic bonding material)..Everyone has a different idea.....Thanks....
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    Maybe post a picture and someone else could offer feedback? Perhaps your steps have a "slip resistant" coating applied within the plaster on the steps, and that's why the slightly different texture over regular plaster? Just a thought...
    Whole pool has the same seal coat...not a slip resistant product. It happened on the 4th of July. We weren't home that night. When we think about it, my husband remembers picking up some black 'soot' like dirt when he was using the net the next morning in that area. The damage looks like a cherry bomb landed & the percussion caused the problem. We will contact our pool construction company to have them do the repairs. Thanks anyway.
