Thread: posphate
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    posphate
    I have read through some posts and the pool school about posphate and understand this forum tends to ignore it yet the pool store deems it's removal as essential.
    Could someone explain a bit more on phosphates or direct me to previous posts/threads that I may have missed?
    Thanx
    16' x 32' IG, vinyl, 80k litre (21k gal), "lazy L" (kidney like at deep, squared off at shallow) shallow 3', deep 8', Hayward sand filter 300 lbs, 20gal/min Mod S-244T, Pentair Superflow VS 1.5 HP Model 342001, Raypak Heater 266K BTU Mod P-R266A-EN-C, 2 returns, 1 skimmer, 1 main drain, diving board, Southern Ontario (Canada) climate.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: posphate
    I'm not an expert so somebody may correct me but phosphates provide nutrients for algae to grew. With that being said algae won't grow at a properly maintained chlorine level according to your cya level. The pool store is trying to make money on something you shouldn't need.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: posphate
    Aimee gets a gold star.
    Search
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: posphate
    Basically, if you do not maintain an adequate FC level (as taught on tfp), then phosphate levels could matter since it is an algae nutrient. However, some (maybe most) phosphate removers only remove inorganic phosphate and don't touch the organic phosphates which are also algae nutrients. In addition to phosphates, one would also need to keep nitrate levels low since that is also a nutrient for algae. See: http://www.troublefreepool.com/new-p...14.html#p90056
    My opinion is the reason pool stores talk about it (and sell removers) is that it can be a good/steady money maker.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: posphate
    Say you've got a wood pile -- that's phosphates (and nitrates) -- representing algae nutrients.
    Say you've got sparks flying into that wood pile -- those sparks are live algae blown into the pool.
    Say you're spraying that wood pile with a fine mist of water -- that's chlorine.
    So long as you've got enough water to put out the sparks (i.e. enough active chlorine to kill algae), then the size of the wood pile (i.e. phosphates) is irrelevant. You won't start a fire.
    If the active chlorine level gets too low so doesn't put out the sparks and they instead turn into flames, then it will take a higher active chlorine level (a lot more water) to put out the resulting fire (algae bloom). However, once that fire is out, you can lower the active chlorine level back down to the level needed to put out the sparks.
    Yes, you can use a phosphate remover to lower the amount of wood in the wood pile, but it's not necessary so long as you maintain the proper active chlorine level. So a phosphate remover needs to be viewed in the same way as an algaecide -- it's insurance if you are unable or unwilling to maintain a proper FC/CYA level, but it's not necessary. And, of course, it's extra cost. And as was pointed out, it's not 100% reliable because if the chlorine level gets to zero, then bacteria can convert organic phosphates (which phosphate removers don't touch) into orthophosphate that algae uses for growth.
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Re: posphate
    Perfectly explained, thanks all!
