Thread: Intermatic timer purchase
    Sep 2012
    Noblesville, IN
    83
    I'm looking for some confirmation that I'm buying the correct timer for my set-up. I have a 230 volt pump and an Aquarite SWG (running on 230 volts also) that are both wired together and come on with the throw of a switch at the pad. I turn both on and off by hand (again, one switch controls both) so the pump only runs a few hours a day. I want to get a timer that 1) will work on 230 volts 2) will turn on the pump and SWG 3) be weather resistant as it's open to the elements. Is the Intermatic T104R what I need? I'm ordering it on-line and would hate to get it and not be the right kind.
    Thanks in advance,
    Matt
    32K in ground vinyl pool installed in the early 1990s
    1.5 HP Centurion pump installed in the September of 2012, replaced under warranty in August of 2013
    2.6 SF Hayward sand filter - age unknown but looks pretty new
    Jandy AE-TI heat pump - age unknown but looks new and works great
    Caretaker in-floor cleaning system - works, but not well....on my list of things to work on.
    Aqua-rite SWG - new in about 2006, T-15 cell replaced in summer of 2012
    22,553
    Re: Intermatic timer purchase
    That's the one you want.
    Sep 2012
    Noblesville, IN
    83
    Great, thanks!
