Results 1 to 8 of 8
Thread: is 150 to high for TA?
    May 2012
    Small midwest town In illinois
    55
    I have been shocking my pool for some time, and it just wont get clear. It is still cloudy, blue but cloudy. For example, when I vacuum the pool from the deck. I can barley see the vacuum on the pool floor.
    All my levels are testing fine, within normal range. So just wanted to check before I started adding any other things besides chlorine to the pool.
    I want my pool back!
    14,600g / 24ft. Round Above Ground with Solar Cover and solar heater panel.
    Vinyl Liner
    Hayward Cartridge Filter (CCX 1500RE)
    2 HP Hayward Powerflo LX Pump
    Pool and solar heater get full sun, when its shinning daily!!
    Using test kit: Taylor K-2006
    Successful BBB user.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: is 150 to high for TA?
    Pls post a full set of test results
    FC
    CC
    pH
    TA
    CH
    CYA
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    From a health and safety standpoint, 150 TA is no problem. It really only matters if you have high Calcium levels, in which case, it contributes to scaling. TA is the very last thing you worry about. It's something to play with when everything else is running smooth and you're bored.
    Can you post a full set of test results? pool-school/read_before_you_post Cloudy water is almost always - 98% of the time at least - a chemistry issue! "All my levels are testing fine, within normal range" tells us nothing - and the fact that the water is cloudy indicates that the levels are not fine.
    May 2012
    55
    FC 15
    CC 0
    pH 7.4
    TA 150
    CH 70
    CYA 30
    sorry, had to run out and check the chlorine before i gave an accurate post.
    Vinyl Liner
    Richard320's Avatar
    Jan 2010
    19,051
    Allrighty then!
    Since you are in the shock process, make sure you have everything running - there's no point having pristine pool water and then opening the solar and dumping a load of cruddy water that's been stagnant inside into the pool.
    Just maintain the shock level, and keep brushing to keep the dead algae in suspension so the filter can grab it.
    May 2012
    55
    This is what I was thinking as well. It has been two weeks since the kids have been splashing and enjoying the pool. Then we had so much rain, and cool weather. Going to have the kids jump in splash around and mix up the water. Then I will vacuum and pray I get my pool back. Thanks for the help. I give more attention to my pool these days, than I do my kids, lol.
    Vinyl Liner
    May 2012
    55
    PS. Forgot to mention I have been running the filter 24/7 since i started back up the shock process.
    Vinyl Liner
    30,431
    You are doing great! It's pretty obvious you have a good grasp of the chemistry. Just keep your FC up and have a little patience....it should get better each day.
