Results 1 to 9 of 9
Thread: TA pH and burning eyes
    May 2013
    Missouri
    53
    My TA is somewhere between 280 and 300 depending on my current definition of color change. My pH is 7.8-8 depending on my current definition of color change....
    I am definitely not interested in burning eyes, so with my inexperience with pH testing I am a bit leery of trying to drop to 7.2 and doing the aeration trick. So, my plan is to drop the pH to around 7.4-5 repeatedly and pointing the eye of my jet thing upwards.
    My questions are: Is there a problem with a slow correction of TA vs a more aggressive approach? Anyone have an idea of how long to expect my planned process to take?
    I plan to eventually add Borates but I know I need to fix the TA first.
    June 2013 24 x 52 Sharkline Heritage AGP (13,500 gal), 2 speed 1 hp pump, 150 lb filter(?), TF-100 test kit
    My first pool ever, pool school student with lots of questions
    30,424
    Re: TA pH and burning eyes
    How long have you owned your TF-100 test kit?
    May 2013
    Missouri
    53
    not quite a week, brand new pool, just filled it the last week/weekend of June.
    PH anywhere from 7.2 to 8.2 is fine to swim in. However, you don't generally want the let the PH get above 7.8 for other reasons. Burning eyes generally only happen when PH is below 7.2.
    Lowering TA will often take weeks, especially if you are making a large change (as you are). It tends to go more quickly at the start, and more slowly towards the end.
    30,424
    not quite a week
    Your TA is likely not that high. Did you read the instructions about wiping the dropper tip on the R-0009 reagent? This only occurs when the kit is very new.
    May 2013
    Missouri
    53
    ok, I will recheck. I've checked it a few times this week, first time was 340 but I didn't wipe the tip (missed that tidbit initially). I wiped the tip this am but am having difficulty determining what "red" is vs red/pink tinge vs a Barbie pink shade. I'm having the same mental difficulty with the CH test and blue vs purple but I'm becoming more confident on that one.
    Did I read somewhere to add muriatic acid in portions like maybe half what the pool calculator says is the "dose" and let it mix in, for say an hour or so, then recheck? I know I need to dilute it in some water before adding it to the pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Quote Originally Posted by hurt5150
    Go reread extended-test-kit-directions-t25081.html The actual shade doesn't matter so much as the fact that it stops changing. TA will go from green to grey to pale pink to barbie pink and that's it. When the last drop doesn't make it any brighter, subtract the last drop. Done.
    CH can take a long, long time, which is why the color is specified. It can stall at purple for a long, long, time and make you think you're getting no more color change. So that one has to actually be a shade of blue, not purple. If CH is above, say 300, use the 10 ml sample size. Directions are in extended-test-kit-directions-t25081.html
    May 2013
    Missouri
    53
    this place is very helpful. I will keep studying! Thanks
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    That was me that suggested the 1/2 dose at a time, at least until you know how your pool will react. Give it a season or two, so you learn your pool's needs etc.
    Once you know for sure how your pool behaves when adding chemicals, then you can modify it upwards. Word of caution -- best to not do whole doses, even when you have learned your pool. Yours being more than twice the size of mine will react more slowly.
