Results 1 to 19 of 19
Thread: New Intex Ultraframe, test kit arriving Mon, want to swim
    Jun 2013
    Prescott, AZ
    10
    HI, we just got our intex 16' ultraframe filled. My test kit will be here monday. I have read the pool school on temporary pools quiet a few times.
    Can I go ahead with 2 nights of Diclor and then swim while waiting on the kit?
    Can we safely swim tomorrow? Do I need to add anything? so far I've added nothing.
    Our SWG is arriving thurs.
    Any advice would be greatly appreciated as our little ones are sooo excited about swimming ASAP.
    Intex 16' x 48" Ultra Frame, just filled, 5,051 gallons.
    TF-100 test kit used. SWG waiting to be set up.
    Regular cartridge filter that comes with pool (1,500 gallon per hour filter pump.)
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: New Intex Ultraframe, test kit arriving Mon, want to swi
    If the water is clear and has some chlorine, I saw swim! Dichlor is fine but you might want to add a starter amount by liquid CL based on your poolcalculator entry. I would say aim for 2-3 PPM CL. Assume you have zero FC each evening with no CYA and your heat. You will not be over chlorinating and you will be much less likely to have an algae issue.
    Also, if you can, consider getting a sand filter for the pool. The 2650 seems most popular. You can get there with the cartridge but sand will make it easier.
    -- Guy --
    30,403
    +1 what techguy said.
    Jun 2013
    Prescott, AZ
    10
    Thanks for the quick response. So just to be clear, all I need to do until the test kit arrives is add the bleach in the amount that the pool caculator gives me (assuming no cya and putting in my area's daily temp) and run the pump? Just wait on the diclor till monday?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by azmountains
    Daily temp has no effect on dosage. all that matters is size of pool.
    Just use the pool calculator to see how much bleach or dichlor - your choice - you need to add to get from zero to 3 FC and add that every day.
    Jun 2013
    Prescott, AZ
    10
    Re: How to lower PH
    Merged by moderator. Please keep your posts together and not in other random threads. Thanks, jblizzle
    TEst response with new test kit, pool filled friday:
    I used the everyday test in blue box
    Cl 3-6 ppm
    ph 8.2
    What do I do now?
    Aug 2010
    Dallas, TX
    4,052
    Re: How to lower PH
    Have you used http://www.poolcalculator.com yet?
    Add half the MA to bring pH to around 7.6. Wait an hour, retest. Let us know if you have any questions with it or with pool calculator.
    Jun 2013
    Prescott, AZ
    10
    HI, I went out this morn to test with my kit to see if MA worked.
    it was around noon and my test read
    CL 1-2
    PH 7.8
    so I put in 16oz of bleach as the poolcaculator recommended, turned on the pump and then took the pool cover off and put on the new solar cover.
    about an hour later my husband tested again from the other side of the pool and he got a reading of
    CL .5-1
    PH 7.5
    does this sound right? if so, what's going on?
    thanks, Rosie
    should i test again from side of the pool i poured the bleach in or is just being used up that quickly. It is pretty sunny here today, btw.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    As for the FC, it's tough to tell if you had much of FC loss when your tests showed 0.5-1.0 and 1.0-2.0. Best case... no loss, worst case your loss is 1.5 FC. A loss of 1.5 in an hour shows algae is consuming it OR the sun.
    What is your CYA?
    Did you measure for CC?
    Why are your answers ranges?... did you test with strips?
    How does the water look?
    Sorry for all the questions.
    -- Guy --
    Jun 2013
    Prescott, AZ
    10
    I'm using the everyday test in the blue box in the k-1000 test kit. we haven't added any stabilizer yet as we just got the pool up and my husband needs to go find some in town. The pool looks clear to me.
    I'm not sure how to measure for CC. is that one of the tests in the kit?
    I thought I was giving my answer range. if not, well...I have no idea YET, how to
    I apologize, this has been a lot to learn!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    No need to apologize. We are all learners once. This process is very different than the one the pool store recommends. That is why I don't go there very often. I drive past it everyday... but stop about 2 times per year.
    To get accurate readings of your FC and CC, you need do the Chlorine test with the powder (FAS-DPD). See the instruction card.
    Basically you add water to the 10ML, add one scoop using the little blue scoop, add drops until the solution goes from pink to clear. Then the the CC testing with the solution created by the FC test.
    -- Guy --
    Jun 2013
    Prescott, AZ
    10
    ok, I did it! I'm getting a slight hang of it.
    FC-6ppm
    CC-0
    TA -120
    And we have the salt and the CYA and we are ready to add it to the pool. SWG is here too.
    Next step??
    Am I good for a swim with the kids before adding the salt this evening?
    Thanks!
    Richard320's Avatar
    Jan 2010
    18,967
    Next step??
    Thanks!
    Yes. But be aware, without any CYA, 6 FC is pretty harsh! The CYA shoulda been hanging in there already. It won't hurt anything just dangling there. Try to keep the kids from playing too rough with it.
    Check out the highlighted post here.
    Jun 2013
    Prescott, AZ
    10
    So now I have another question i can't find the answer to through the search.
    The intex SWG instructions say I need 1.3 pound of CYA, which we bought the hth kind at walmart, 96% pure.
    How do I tell how much is 1.3 pounds. ? It is in a 4 pound canister. the pool caculator is doing the measurements differently so I don't quite get how the equate.
    I'm guessing i should just put a portion in as per the recommendations on this site.
    I saw a post where someone dissolved 1/2 pound in a bucket and put it in pool overnight. Otherwise, I'm wondering how one can put a pound in a sock and still swim in the pool while it is dissolving?
    so, how do i measure a this stuff. nothing about it in the directions for SWG.
    Jun 2012
    Butler, PA
    336
    I put my Stabilizer in a pair of my daughters tights that she won't use next year or this last go I bought woman's nylons placed the amount I needed in them and let them dangle in front of the return. I did this Sunday. Next Sunday I will test the water to see what my reading is. This takes 1 week to register.
    If I would have needed less than 4 pounds I would have weighed it, unless I needed 2 pounds and I would have eyed it. As you need a specific amount and you are new to learning your pool, I would weigh out the amount it requires and dose accordingly.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Richard320's Avatar
    Jan 2010
    18,967
    You're only aiming for 30 on the CYA?
    A kitchen scale is the ticket. Or borrow the scale at the post office, or the grocery store. Or, even easier...weight and volume are pretty close on CYA. 2 kitchen measuring cups of the powder should be pretty darn close to 1.3 lbs. Whatever amount it's off won't be enough to read on the tester.
    Pour it into a sock or a nylon, tie it off, and suspend it in front of the return or tie it to a floating toy and let it bob around.
    Jun 2013
    Prescott, AZ
    10
    well, the directions state CYA needed for start up. for my size pool 1.3 lbs. otherwise, it says they recommend CYA be at 1% of salt or 1lbs of salt = 1 lbs of CYA.
    So for my pool, 125 lbs of salt, 1.3 lbs of CYA.
    Seems at odds with Pool caculator.
    What would you recommend?
    Jun 2013
    Fallsburg, NY
    258
    Intex's recommendations are low, shoot for 60ppm on the cya in the pool calculator
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Trust the recommendations here.
    The bottle instructions are assuming lots of things they don't know about you, your pool or your needs. This is probably true of all chemicals sold in pool stores.
    We are making recommendations based on your test results, your pool and your needs... and the combined knowledge of the BBB process.
    -- Guy --
