Thread: just to be sure filter vacuuming thing multiport
    When vacuuming on waste a pool filled with dead algae and still a light green, that green monster fine mist returns. confirmation dial valve or spider gasket please thank you.
    could something prior to this could have caused this situation. please thank you.
    38,251
    Re: just to be sure filter vacuuming thing multiport
    Welcome to TFP!
    I am a little unclear of your problem ... lost in translation?
    Are you saying you are getting algae back into the pool through the return jets while you are vacuuming to waste?
    yes, While vacuuming on waste, "fine particulate" which I am guessing is the algae dust that I just vacuumed of the bottom of the pool returns through the jets.
    30,403
    What type of filter is it? Sand, I assume. Does it need to be cleaned/backwashed?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Zizoid
    On waste, nothing should be going to the filter and out the returns. If you're sure you're on waste and not recirculate, then it's a good bet the spider gasket in the multiport is leaking.
