Results 1 to 11 of 11
Thread: Trouble with Hayward weir
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    I recently installed a Hayward skimmer on my Intex pool. It works great while the pump is on, but when it's off, the weir door does not float. It just stays at the bottom. And even if it did float, there does not seem to be anything to stop it from opening into the pool. Seems stupid to me. I thought that the weir was supposed float up when the pump is off and stay shut to keep debris from floating back into the pool. The instructions make no mention of any sort of stopper. There are no tabs or stoppers or anything whatsoever on on either the weir or the skimmer itself to keep the weir from opening into the pool. And even if there were, the weir doesn't even float in the first place. The weir simply snaps into two holes on either side and swings both ways. It just seems very poorly designed. Am I missing something really obvious or is this how all skimmers are? The skimmer I have is the Hayward SP1091LX Dyna-Skim.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Trouble with Hayward weir
    The weir should have white foam on the back side to make it float.
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Nope, there is no foam on it. Was I supposed to attach it? Because no such foam was even included with it and the instructions make no mention of it either. I suppose I could glue some styrofoam to it. Would that work? And then, how do I stop it from opening into the pool? Should I glue a piece of plastic to the outside of the faceplate maybe?
    Intex SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    There should be a place for the foam, does yours have it on the non pool side near the free end of the weir?
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    It looks as if there's some sort of "holder" on the back of the weir for the foam, but I'm not sure. And like I said, no such foam was included or mentioned in the manual. Plus, all the pics in the instructions do not show any foam on it. I glued some Styrofoam to the back and now it seems to float, but that still doesn't solve the problem of it swinging into the pool. I guess I can rig something up, but I don't see why I should have to do this in the first place or how it got such high reviews on Amazon given this flaw. How does a weir typically stop from swinging into the pool?
    Intex SWG
    SW Indiana
    9,198
    I don't see how the weir can swing into the pool. Can you post a picture?
    22,543
    My weir can swing into the pool when the pump is off. The foam keeps it floating high enough that it's not a problem, but there's nothing to stop if from swinging into the pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Same as bama here...I have a agp hayward widemouth skimmer and there are no stops preventing the weir door from swinging back into the pool. Here is a picture of the one I have minus the widemouth extension: http://www.poolsupplyworld.com/Haywa...r/SP1091WM.htm
    SW Indiana
    9,198
    Is your water level about halfway up the skimmer opening?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    My Aqua Leader wide mouth has a stop for the weir if I use the OEM weir, the pool also had a Hayward weir in the pool box and it doesn't stop. I prefer the OEM one after I replaced the foam. Although it clanks a little with wave action when the pump is off.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Yes, my water level is about halfway up the skimmer. Here's a picture. With the Styrofoam I glued to it, the weir will eventually float to this position when the pump is off. Sounds like I'll be getting a new skimmer next summer.
    Intex SWG
