Results 1 to 9 of 9
Thread: shocking my pool
    shocking my pool
    hello everyone, i'm new to this and have a question... after spending $40 dollars on bleach trying to shock a green pool, i was running out of time and money so i put 5 lbs of cal-hypo in the pool two days ago, it's back to blue with cloudiness. i know my test are not accurate with the pool in shock mode but here they are.
    stabilizer - 80
    ph - 7.4
    alkalinity - 110
    hardness - 0
    color of my chlorine test - deep orange
    do i just wait now?
    24' x 52' Round AG 11,200 gal., 2 HP pump Cartridge Filter
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: shocking my pool
    Welcome to the forum.
    Spend a little time in Pool School. Link is upper right corner of every page. We want to help, but we'll be speaking Yiddish unless you do a little reading first.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, juicierthnfruit
    What type and size of pool do you have?
    The shocking process we teach on here is a little different then just adding product to the pool...it is a process of holding the chlorine level appropriately high until the algae is gone. See this pool school article: http://www.troublefreepool.com/pool-...king_your_pool
    Jun 2013
    SpringHill FL
    415
    Sounds like your first step would be to get a good quality test kit that will allow you to actually see what you need to do. The TF100 or K2006 are the best kits out.
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    thanks, i'll go over the pool school again....
    thanks linen, i read the pool school and realize the shocking using the bbb method is a process, i only had 2 days to spend time with the pool, i don't any help to keep watch over it. so i figured i't use the cal-hypo to get it back to blue, then start from there with the bbb method.
    I have a 24" round 11,200 gal AG vinyl 2 HP millennium cartridge filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Part of the problem with your idea is that Cal-Hypo can cause cloudiness all by itself, so you can't tell if the cloudy water is from algae still in the water or the addition of Cal-Hypo that you used to try to clear the algae. This is part of the reason we preach using only bleach for chlorination, particularly for beginners who may not understand the secondary effects of the other forms of chlorination.
    thanks for clearing that up for me.. i really appreciate that
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    What strength Cal-hypo? Even the 73% stuff only took FC to 39, which is still less than mustard shock level. The 58% stuff would have barely put you into shock level! So I'd say you got lucky. A logical orderly approach works better. I had an infection once, but I wanted the pain to go away right now. I didn't have time to take those antibiotics twice a day for ten days. I should have just taken the whole bottle at once.
