Results 1 to 17 of 17
Thread: 12x22 ultra frame pool pump
    Jun 2013
    Southeastern British Columbia
    79
    Hi the tfp friends!! Do any of you who have an ultra frame or larger frame pool use the cartridge pump with the inwall skimmer that comes with it? Or has everyone upgrade to a pump and sand or de filter? Wondering if we can get away with using the cartridge filter for this year as we have a lot of work and cost cut out for us with the pool as it is without re doing the pool plumbing as well. But if it means the pool will be better off then we will do it!
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    22,539
    Re: 12x22 ultra frame pool pump
    The best thing to do is try the filter and pump that it comes with and if it doesn't work then get the larger unit.
    Jan 2013
    Aruba
    229
    The first 2 years i used the cartridge filter that came with the pool it was okay untill i got algea then when i tried to vacuum the dead algea i noticed that everthing was returning back to the pool.so this year the first thing i did was to get the intex 2650 sand filter and it has been working really really good
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Jun 2013
    79
    Would it be possible to use a pump and sand filter from an inground pool on my intex pool? I was reading pool school and it was explaining the difference between the two and now I'm just not sure if you can interchange them.
    Jan 2013
    Aruba
    229
    That i'm not sure about,maybe someone here can help u with that.
    Can't see why it wouldn't work
    Thru wall skimmer,
    Hard plumbed
    Jun 2013
    79
    There is a lady who has filled in the pool in her yard *gasp*.
    She is playing kinda hardball considering there are probably only a handful of people around the area here who have or want to have a pool. She is saying she paid 700 for the pump and only used it one season. She wants 400 for it and the sand filter.
    Jan 2013
    Aruba
    229
    Seems reasonably priced
    Thru wall skimmer,
    Hard plumbed
    Jun 2013
    SpringHill FL
    415
    An inground pump on an above ground pool? That is what your trying to do correct? You should not have an issue from what ive read
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jun 2013
    79
    Yes,an inground pump and sand filter on a polygroup 13x22 rectangular ultra frame pool
    Hoping that it works
    Jun 2013
    79
    Do you think that a 1/2 hp pump is enough for the 12x24 foot pool?
    I think I would just invest in a new pump for my pool as you could get one cheaper than 400 and not have to retrofit. Check Amazon for the intex sand filter for your pool. Or check on craigslist for a used one. Still the 400 may seem reasonable but for youyr pool a new one cheaper seems a better deal
    http://www.amazon.com/s/ref=nb_sb_ss_i_ ... Caps%2C397
    ProSeries Above Ground 20x4 Sand filter 1 hp
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Do you know the make and model of the pump. Some 1/2 hp inground pumps can move quit a bit of water (maybe more than you need/want).
    Do you know the size of the filter?
    Jun 2013
    79
    I think connie is right. I looked at a few websites today and I can get a brand new pump and filter set for under 400$ and then I have some peace of mind that its new
    I will post the brand we plan to buy as soon as we narrow down the choices.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Give us the size of you pool and we can make some suggestions/recommendations.
    Jun 2013
    79
    It's 13x22 52"height.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by kshuf
    I guess that should be obvious from your title
    That pool should be around 8600 gallons. So we would recommend as minimums:
    • 1.6 sq. ft. sand filter
      128 sq. ft. cartridge filter
      24 sq. ft. DE filter
    Although the Intex 2650 filter pump combo is a little small for your pool (1.4 sq. ft. sand filter) it would be a good value and can usually be found for under $200 (sometimes under $150)
    keshof here are some sites that have them on sale.
    Perhaps you may want to look at them and the warranties involved.
    http://www.ebay.com/itm/Intex-2650-GPH- ... %26ps%3D54
    http://www.amazon.com/Intex-56671EG-650 ... lter+pumps
    **** this looks like an awesome deal!!
    http://www.amazon.com/Hayward-S210T93S- ... lter+pumps
