Thread: First salt in new pool
    It has been 4 weeks since DB plaster. Based on DB specs I can add salt now. Is there any other reason to give it more time to cure or is the recommended 4 weeks plenty to ensure no damage to DB? It tested at 600 ppm. I need to add 720 pounds to get to 3500.
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    Aug 2010
    Dallas, TX
    4,052
    Re: First salt in new pool
    Ask the pool builder, that way you aren't voiding your warranty.
