Results 1 to 8 of 8
Thread: Heater recommendation?
    We're going to put a heater in next year. 24' AGP, 13,300 gallons, Chicago.
    I don't have the room or desire for solar. I'm pretty much set on a natural gas unit. Any suggestions on a brand and btu size?
    Thanks in advance!
    24' AGP, 54" - 13,300 Gallons at 47".
    AquaRay Cleaner
    Hayward Swimpro Voyager Filter/2 Speed 2 HP Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Heater recommendation?
    I would go for a 400K btu unit and be prepared to pay a lot (for the gas) when you want to heat early and late in the season.
    May 2009
    Mn
    198
    I second the 400k. Some will tell you it is overkill but in Chicago you may want to swim those last days in the fall and not have to heat your pool for days. My sister has a 333k and she can heat 10 degrees in a day in the fall. Mine is a 266 and we can barely maintain the overnight loss let alone raise the temp.
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    Thanks. I was going to go with a 250k, so I'm glad I asked.
    Which brand? Thanks Again!
    AquaRay Cleaner
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    +1 for the 400K BTU. It will take so many BTU's to heat a given amount of water to a target temperature. I would rather get there sooner rather than later. As the kids on the AT&T commercials say, "Faster is better".
    As for brands, the inspector who inspected our house commented that the Teledyne Laars heater we have is built like a tank. Mine's 20 years old and still works great. Don't know if this "built like a tank" comment applies to the current Teledyne Laars heaters but if I were in the market I would start there based on the longevity of my current heater.
    Aug 2009
    SW Wisconsin
    518
    just my two cents..but I live further north than you....(Wisconsin) I have a 33 ft Diam AGP..and have a Hayward H200 on the pool, and it does just fine during the colder parts of the season. I do close my pool in late September, BUT I never have any issue maintaining nice swimming temps with my setup.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jan 2013
    Houston, TX
    1,079
    400k raypack (rheem).
    This is my second pool with the raypack and the darn thing is bombproof.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jul 2013
    Rhode Island
    13
    If a bigger heater will allow you to heat up the pool in (say) 12 hours instead of 24, so you can turn it on Friday night to get ready for the weekend instead of turning it on Friday morning, then you will save money because the pool will be rejecting heat to the environment for less time. Just like saving money bu turning off the A/C when you aren't home.
