Results 1 to 11 of 11
Thread: Shock and high CYA
    Shock and high CYA
    Hi,
    I have a couple of questions.
    I am going to shock my pool for the first time (the real way with liquid and not powdered "shock").
    My CYA is 100 so. Know I need LOTS of chlorine per the calculator.
    My questions:
    1. Is it better to do a partial drain first (few inches so I can water my lawn. In so cal drought)
    2. If I water my lawn, what is an OK chlorine level to not harm vegetation?
    3. How soon can we swim after the shock?
    Thanks!
    New pool owner 3/2013 14,000 gal pebble tec, 7 ft jacuzzi with spillover into pool.
    FNS +48 DE filter, raypak2100 heater, Pentair whisper flo 1.5, Hayward pool cleaner. TF 100 test kit.
    Aug 2010
    Dallas, TX
    4,052
    Re: Shock and high CYA
    Are you sure the CYA is 100? How is this being measured? When CYA reads 100, it very often can be much higher as most tests top out at 100.
    I have never seen FC hurt a lawn, even at shock level. And if you will lower the CYA level now, watering your lawn in the process, the shock process is going to be far cheaper and easier.
    You can swim when the shock process is complete, and FC has fallen below shock level.
    You've read How to Perform the Shock Process in Pool School?
    More info. I have a small amount of algae I noticed on the tile grout. I have also noticed an intermittent odor (can't really describe) when in the jacuzzi with the jets on. Could this algae be causing the odor? Water itself smells fine.
    I have read over the shock process briefly but will re-read before I do anything.
    Aug 2010
    Dallas, TX
    4,052
    Be sure you brush off that algae during the shock process.
    An odd odor should always make you wonder what is going on. It doesn't smell of bleach?
    No, I don't smell bleach, indicating chloramines. It smells kinda organic to me (earthy) but I'm not sure. Odor remained even after cleaning filter and new DE. It is quite a puzzle.
    Aug 2010
    Dallas, TX
    4,052
    It's never a bad time to perform an OCLT. All it really requires is that you test after dark and again before the sun is on the pool.
    pool-school/overnight_fc_test
    You should see less than 1ppm loss overnight. And you are correct, this is the right thing to do at this point.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    We would recommend lowering your cya level (maybe down to 70 since you have a swg) before doing the shocking process.
    I would like to exchange the water gradually in order to use the water on my lawn, but this will probably take too long to lower the CYA in a timely fashion. Will have to give this some more thought. Thanks for all the help. It is much appreciated.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Well you can do the shocking process at higher cya levels, but it will likely take more bleach/liquid chlorine...and more vigilance during and after the shocking process.
    Jun 2012
    Howell, NJ
    977
    Have you done the diluted CYA test? Lie was said, most CYA tests read anything over 100 as 100, so it could be higher.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    I did do the diluted test for CYA. I'm confident my level is 100
