Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Low CYA in INTEX pool
    Jan 2013
    Aruba
    229
    I added 1 lb of CYA using the sock method.everything has desolved since monday but i can't get a reading of the CYA.
    Before i put the CYA in the sock i read on the bucket to add 30 ppm of CYA in a 4440 gallons add 1lb so i did that but now when i put in 1lb of CYA in the pool calculator it says that will only bring my CYA to 12 ppm.
    So should i add more CYA or just leave it alone for a week and check it then?
    FC:2.5
    Ph:7.4
    TA:90
    CH:40
    CYA :12 according to the pool calculator/also just tested it well below 30 ppm
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Aug 2010
    Dallas, TX
    4,052
    Re: Low CYA in INTEX pool
    Trust poolcalculator. If you think you added half of what you need, and after 5 days you still see almost nothing, I'd venture to say you need to add another pound. Then you can see if that puts you around 25 and adjust from there.
    Jan 2013
    Aruba
    229
    Ok i'll leave it for now and check it back maybe monday or tuesday.
    I'm using a 3" trichlor do you think if the CYA level reach 25 just leave it there or raise it?
    Thru wall skimmer,
    Hard plumbed
    Aug 2010
    Dallas, TX
    4,052
    30-40 is where you want to be. Those trichlor tabs will help you raise your CYA too. Just keep "tabs" (pun intended) on how many you use and track the effect in the pool calculator.
    Jan 2013
    Aruba
    229
    I have added only a 3" trichlor so far
    Thru wall skimmer,
    Hard plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Typically the 3 inch tabs are about 8 oz of trichlor...so each one should raise your cya ~ 8 ppm...so be careful using too many.
    Jan 2013
    Aruba
    229
    Woww i didn't know it had that much CYA in it,
    Thx for the info
    Thru wall skimmer,
    Hard plumbed
    Aug 2010
    Dallas, TX
    4,052
    all hail poolcalculator.com!
    At the bottom you can look up the effects of adding different chemicals.
    Jan 2013
    Aruba
    229
    Thx for all the help.
    Thru wall skimmer,
    Hard plumbed
    Jan 2013
    Aruba
    229
    So after a few days of last checking the CYA tomorrow i'm gonna check it.but according to the pool calculator i have added 1lb of CYA so that will give me 27 ppm and also added 2x3" trichlor tablet so in total i should have a CYA of 42ppm.
    Extra: i have a leak so today i had to add like 2" of water just to get the water to mid skimmer level,so if tomorrow the CYA level is at 42 i should just leave it right?
    Thru wall skimmer,
    Hard plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    42 will work fine...but be aware that leaks will cause cya to go down.
    Jan 2013
    Aruba
    229
    I gave up on trying to patch the leak it's where i added another return and i tried everything it just won't seal ,so now i just let it leak.
    Tomorrow gonna check everything again
    Thru wall skimmer,
    Hard plumbed
    Jan 2013
    Aruba
    229
    Just checked everything here are the results,should i add more CYA or just let it at 30?
    i have 2x3" trichlor tablet in the pool
    FC:2
    Cc:0
    PH:7.3
    TA :80
    CYA:30
    Thru wall skimmer,
    Hard plumbed
    Jan 2013
    Aruba
    229
    Today checked TA,PH,FC
    TA:70
    PH:7.4
    FC:1.0
    CYA:30
    Just wondering if i should put in another 3" tablet to raise the FC and CYA or just start adding bleach tomorrow and let the CYA at 30?
    (Gonna start looking around for some more concentrated bleach)
    Thru wall skimmer,
    Hard plumbed
    Jun 2013
    SpringHill FL
    415
    I just noticed your in Aruba if i were you i would be floating in the ocean
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    How much sun does the pool get ? You can always bump it up some if your losing to much to sun and heat.
    It's easier to add than take away
    Jeff
    Jan 2013
    Aruba
    229
    The pool gets full sun from 7am to 7 pm.
    Even in the moring the water is still a little warm
    Thru wall skimmer,
    Hard plumbed
    Jan 2013
    Aruba
    229
    I don't like the ocean that much because i don't like the feeling of the salt on my skin
    Thru wall skimmer,
    Hard plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would up your cya to 50 ppm.
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It's your call then. 40 ppm might save some chlorine loss. You'll just want to never let it fall below 3 ppm. 3 to 7 is the target.
    Jeff
