Results 1 to 8 of 8
Thread: Sand does not have to be replaced?
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Just read the post on rinsing sand and was wondering how and where does the garden hose water go? If I do this cleaning do I need to set the cap dial to backwash and then the hose water will exit that way? Or am I suppose to remove the drain cap at the bottom of the sand tank?
    A service tech who was at my house recently (assesing a slipping liner) told me sand should be replaced periodically. But I have no clear answer as to when I know it is time. So just to confirm, sand does not have to be replaced? If so, how would I know?
    16' x 32' IG, vinyl, 80k litre (21k gal), "lazy L" (kidney like at deep, squared off at shallow) shallow 3', deep 8', Hayward sand filter 300 lbs, 20gal/min Mod S-244T, Pentair Superflow VS 1.5 HP Model 342001, Raypak Heater 266K BTU Mod P-R266A-EN-C, 2 returns, 1 skimmer, 1 main drain, diving board, Southern Ontario (Canada) climate.
    Aug 2010
    Dallas, TX
    4,052
    Re: How often to change sand in sand filter
    I replaced my sand last year because my filter broke (broken laterals). Other than that reason, I would not have replaced it. It was installed in 89.
    Re: Sand does not have to be replaced?
    When rinsing sand, the water simply overflows out of the filter and onto the ground. Do not remove the drain plug when doing this. You want the overflow to go up, not down.
    It is a common misconception in the pool industry that replacing sand is a good idea. I guess it is for the people who sell you sand or get hired to do the work for you.
    The only time you need to replace sand is when it has become clumped so badly that you can not break the clumps up by hand.
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    So that water overflows out the same place where back washing goes?
    Thanks so much, what an awesome forum
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    No, the multiport valve is removed (or the top cap opened for sand filters with side valves) for this process and the water and crude just overflows out of the open top.
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    shane4's Avatar
    Jul 2013
    Ontario Canada
    69
    Ahhhh, I get it. DOH!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by shane4
