Results 1 to 9 of 9
Thread: Need advice/opinions
    May 2013
    New Jersey
    176
    Hi guys
    I posted something to this effect a little while back (along with another issue) but didn't get many responses in terms of this particular question and I'm looking for advice/suggestions.
    When initially coming on this awesome site, we were using chlorine tablets through our chlorinator. After reading on TFP, I had my husband shut off the chlorinator completely and use liquid chlorine. At that time, I didn't even think of how many tablets were remaining in the chlorinator when he shut it off, and I honestly didn't want him retrieving them from there at that time because they would have been all wet and difficult to remove, not thinking about them sitting in there in the heat, dry all summer!
    Now, it's probably been about a month since we've shut the chlorinator off, still with the tablets in there. My dilemma is what do we do now? The pool is balanced so nicely right now with the perfect amount of CYA that I am afraid to let even the small amount of tablets we have in there run just to get rid of them. (I worry that the heat is heating them up in the chlorinator to where it can explode if opened - I'm a total worry wart - is this thinking even rational?)
    Anyway, do I tell my husband to try to open the chlorinator and remove them by hand (or tool)... is that even safe since there hasn't been any water flowing over them? OR, would you just turn it back on until they are entirely dissipated, risking your CYA level increasing a little? I think there are probably about 5 or so in there right now so I can't imagine it will increase that much. Does anyone know how much the CYA will increase in a 25,000 galloon pool if there are about 5 tablets?
    Any advice is greatly appreciated!
    7+ years, inground, 25,000 gallon, vinyl, sand filter.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Need advice/opinions
    There is an "Effects of Adding Chemicals" near the bottom of the PoolCalculator. Remember to add your pool gallons at the top
    What is the CYA level now?
    You're done SLAMing when:
    May 2013
    New Jersey
    176
    Quote Originally Posted by Butterfly
    Oh, that's right! I'm just not sure how many ounces to put in the calculator for trichlor since I don't know exactly how many tablets are in there.
    CYA at 40.
    Feb 2012
    Cypress, TX
    131
    Should be around 6ppm. You can use the pool calculator to be sure.
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    May 2013
    New Jersey
    176
    Quote Originally Posted by Bluechip
    Do you mean the CYA will increase 6 ppm? That sounds like a lot to me because then we'd have to go by the level of 50 CYA when determining the amount of chlorine we'd need. How do you figure out how many ounces there are per tablet?
    Feb 2012
    Cypress, TX
    131
    I assumed you were talking about the 3" tablets. They are around 7-8 ounces each. My pool is just a little bigger than yours and each tablet raises my CYA 1ppm so yours would be just a bit more than that. Just plug in the numbers to the pool calculator to be sure.
    May 2013
    New Jersey
    176
    Yes, you're right on. Just checked the calculator. That would bring my CYA to the higher level of norm.
    I really don't want any more CYA in the pool and we do plan to go on vacation for a weekend at the end of August in which we were going to use some tablets then so that would put even more CYA in if we do turn the chlorinator on now as well. I know how difficult it is to remove CYA from the pool and it's really not an option.
    What would you guys do? Would you just try to remove them manually from the chlorinator instead to avoid that, or would you risk increasing the CYA and turn the chlorinator on? I don't like the thought that the tablets are sitting in there in the heat and it's going to start getting pretty hot and sunny this week. I feel like we have to do something. I don't know. I certainly don't want to risk any danger opening the chlorinator, but there may not be any danger in doing so. Can't confirm that either way.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, if it was my pool, I would turn the chlorinator on low, adjust the FC maintenance level to 50 CYA, and backwash just a little longer than needed each time.
    Keep an eye on pH.
    May 2013
    New Jersey
    176
    Keep an eye on pH.
    Thank you so much for your opinion I think that's just what we'll do.
