Thread: Intex SWG and Timer Question
    Jul 2007
    Hillsborough, NC
    525
    a thought prompted by another thread.... I have my pump on a timer and have the Intex SWG. My SWG will automatically start when it is plugged in and run for the progarammed time. After that, it will start again at the time it was plugged in. I don't haves it plugged into the timer. We have had a few power outages here recently. The SWG tries to start when power is restored but if the timer has the pump ioff, then it gets the low flow warning. Is there a reason not to plug the SWG into the timer?
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    38,284
    Re: Intex SWG and Timer Question
    I would actually recommend plugging the SWG into the timer to prevent the situation you described.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Depends on the model of intex swg, a few years ago intex started shipping them with apparent non-volitale memory that would remember the run time...I think this was the same time they added the (stupid) copper bars and reduced the chlorine output by 1/2...somewhere around 2010. If you have one of these then I would think it will work. If you have the older (non copper and twice the chlorine output) swg, then it will go back to the default run time when power is lost and then restored.
    Jul 2007
    Hillsborough, NC
    525
    Mine remembers the run time, so I will plug it into the timer. Why they would ship it without NVRAM at all is beyond me. I disconnected the copper bars on mine.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Quote Originally Posted by crokett
    Save money maybe, mine has no NVRAM but still worth the short money. So you gain the better memory but the older ones pump out more chlorine. 3 to 4 hours a day is plenty for my 18'x33' pool. Maybe I could bodge the new and old type together to make a better one....
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
