Thread: Green slime fails to deter swimmers
    East_Akl_Neil's Avatar
    Apr 2012
    Auckland, New Zealand
    70
    Saw this article and thought of you guys.
    Who needs Algae prevention.....
    http://www.stuff.co.nz/world/asia/88...deter-swimmers
    Late 1970's 39000L IG Concrete Pool with Vinyl Liner
    Austral FT55 Sand filter
    Hurlcon E170 Pump Brochure,Manual
    32-40mm Pipe work
    Living in beautiful New Zealand
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Green slime fails to deter swimmers
    No thank you. If I can't see through it, I'm not going in it.
    Butterfly's Avatar
    South Carolina
    10,045
    ew
    Talk about "can't see the bottom"
    You're done SLAMing when:
