Results 1 to 12 of 12
Thread: Another pool mod, sort of.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Here's what I threw together today, and why.
    Wife was complaining that the original "ladder" that came with the pool was too narrow and didn't feel sturdy. I agreed. She's right.
    So since I had the time and $$ in the same place at the same time (believe me, that is actually a rare event!), I built this today:
    Daughter got up on it before I had steps or ladder attached, and was dancing around on it. Very sturdy, she says.
    The half of the original ladder is only temporary, as is the decking, for the next rare event of time and $$.
    Decking will be replaced with normal PT wood, when I build the next section.
    Plan is to build a set of steps that are on a hinge arrangement out of composite lumber with stainless fasteners, so it can be removed from the pool when I close it for the winter.
    The deck itself will grow, slowly, to encompass about 1/3 of the pool. It will be build in sections so I can remove them when needed.
    Rails will be made along with the next section.
    None will be permanently set in concrete, as we are planning to eventually upsize to maybe an 18'. I doubt we would be able to go any larger than that, too small a yard.
    Jun 2013
    Southeastern British Columbia
    79
    Re: Another pool mod, sort of.
    Nicely done!
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    Jul 2007
    Hillsborough, NC
    519
    That's a cool idea - I wish I'd thought of it last year for our AG. It would have solved a few problems for me.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Very cool How about a pic of your heater -- I am so jealous of your diy fixes, including the cheap but effective heater!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Oops, just opened the other pics and saw your whole set up. Love the deck/platform!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Thank you all for the kind comments!
    This is what happens when you have more time than $$, and a background in the construction trades.
    As I said in another thread, "If I don't know something, I find someone who does". It used to be the local library, now why take the trip? The internet has almost all of what you need to learn to take care of the task at hand.
    Another reason for !!
    Is there a clock smiley somewhere?
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Wow, Ive been looking for a way to get my mother in law in the pool to cool down. I was going to build a bigger deck around the pool but funds arent there for that. but this looks like something that would work and with some railing and ballisters it would be safe for the ol' girl to climb up.
    I like your idea of removable sections as I cant build a permanent structure without permits. Going out to round up some lumber and hardware will post pics of it when Im done. If my kids let me finish it today.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    Charlie... You can come to my house
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Jun 2013
    79
    I am very curious to see the heater!!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    You should have access to the pics, the url I linked goes into the album the pics are in.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Ok, have another section of the deck done.
    Here's what I've got:
    I've cut it so the decking hangs over the edge of the pool by a couple of inches. Good place to sit with your feet dangling in the water. Deck isn't quite wide enough for a chaise, but a couple of chairs should fit.
    Wife suggested I move the ladder to the end of the new section, so I'll be doing that along with adding the railing.
    One more section is all she wants, that one will go on the other end next to where the ladder is now.
    In the middle of all this, I'm trying to get my mess cleaned up, and hard plumbing the pool. Still have to move the rest of the dirt and clay I dug out for the pool. Little by little, it's getting done.
    May 2013
    Moore, OK
    7
    I did something very similar, we needed something better than the ladder but didn't have the funds this year for full deck.
    I used the ladder for the steps up the deck and the other half was bolted to the deck to get in and out of the pool. It's amazing how much sturdier the cheap ladder is when bolted to a strong surface. The kids absolutely love it, they constantly are up and down it running and jumping in. [attachment=0:26zxdlk1]ImageUploadedByTapatalk1375675143.349055.jpg[/attachment:26zxdlk1]
    Only pick I have they were actually using it as their duck blind to hunt ducks.
