Welcome to TFP
When you have iron in the water you need to use sequestrant to bind to the iron and prevent it from redepositing as stains. Unfortunately, sequestrant breaks down over time, you need to be constantly adding more. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. ProTeam's Metal Magic and Jack's Magic The Pink Stuff (regular), The Blue Stuff (fresh plaster), and The Purple Stuff (salt) are some of the top sequestrants. Also, keep your pH between 7.2 - 7.4.
There is a chance that the iron may precipitate out when chlorine is added. If this happens, you can either add more sequestrant (if you are entertaining and need the pool to be absolutely clear right now) or, if you can deal with the rusty orange color for a while, you can try the "paper towel" method which involves placing paper towels in the skimmers. The paper towels may remove some of the precipitated metal particles. No guarantee this will work, but it is a low cost - low impact alternative worth trying, so I will put it on the table. Some members have had some success with this (see this post:
http://www.troublefreepool.com/a-tale-of-two-filters-and-ugly-rusty-water-t46130.html) - scroll towards the bottom to see a picture of the iron filtered out by the paper towels. If you try this method, check on the paper towels every couple of hours or so while the filter is running. Replace towels as needed.
Even if the paper towel method removes some of the iron, you may still need to continue using a sequestrant but perhaps less of it if the paper towel method was at least somewhat successful.
A couple of things to help us help you...
- 1. Please add to your profile the state and nearest city in which you live. Your climate is important to the advice you receive. By doing this, it will appear in all your posts without you having to enter it each time.
2. Suggest adding information about your pool and related equipment in your signature. By doing this, it will automatically appear in all your posts so you do not have to re-enter it each time. If you have a SWG, please include those letters in your signature so it stands out as the advice for SWG vs. non-SWG is often different.
Here's how to do both of the above:
Adding location to your profile and pool info to your signature.
