Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: new pool
    Jul 2013
    central North Carolina
    27
    new pool
    Just finished my pool instead of paying to fill I pumped out of pond. Green and cloudy tried shocking and took sample fc 0.13 tc 20 cc 19.87 ph 6.9 ta 0 ch 33 ca 9. What do I need to do without draining pool?
    16000gl ig fiberglass 1.5 hp vari sand one skimmer
    Jul 2013
    27
    Re: new pool
    Sorry forgot profile 16000gl fiberglass ig sand filter 1.5 hp vari one skimmer
    22,543
    Re: new pool
    There are a few things that look suspicious.
    To start with, if the pH is 6.9 the TA can't be zero.
    A ca (I assume that's cya) of 9 is almost impossible to test for.
    A good test kit is the first thing you need.
    Answer a few questions and maybe we can help.
    What have you chlorinated it with?
    How much did you use?
    Have you been running the filter 24 hours a day?
    Have you had the water tested for metals?
    Has the pond had algaecide added to it?
    Jul 2013
    27
    Re: new pool
    I took sample to local pool store they put samples in some kind of machine. Bleach and turbo shocker maybe 7 gl and 12lb. yes 24 hrs a day. 0 metals. no algaecide. Sorry a few days ago I did cut filter off after I put( back to blue) in pool. next morning crystal clear with about 2 inches of algae on bottom. Vaccumed to waste nice and slow added 3lb of tubo shock with filter running and bam cloudy green. That's when I had it tested.
    Jul 2009
    Fort Wayne, IN
    392
    Re: new pool
    we filled ours from our pond too. Took a couple days until water was sparkly and wonderful. However, we ended up with a rather high copper reading because we were unaware the neighbor was treating the pond.
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    22,543
    Re: new pool
    You haven't really shocked the pool. Read the article in pool school on how to shock your pool.
    If you will hold it at shock level it will clear up fairly quickly.
    Theresa is the reason I asked about the algaecide in the pond. I remembered their ordeal.
    Jul 2009
    Fort Wayne, IN
    392
    Re: new pool
    Dave,
    I'm flattered that you remembered
    Theresa and/or Gary
    Jul 2013
    27
    Re: new pool
    Alright,put borax & soda in took sample to store here it is fc6.89 tc6.89 cc0 ph7.6 ta164 ch243 they say cya9. They told me to put 1 bottle of algae shield in which I did and said don't shock for 48hr but after that add 3# turbo shock. Ok i'm really starting not to trust those guys, I know they got to make aliving but come on man. my question is can I go ahead and start shocking the water per pool school or do I need to wait 48hr. And I ordered the test kit tfp recommended, I live in NC so maybe it wont take long. Thanks ps went to the store before I seen you guys reply.
    Aug 2010
    Dallas, TX
    4,052
    Re: new pool
    You don't need algae shield in a properly balanced pool. They are just taking your money. I'm betting that shock is Cal Hypo, as your CH numbers are high but CYA numbers are low.
    You are correct to not trust them.
    Wait for your test kit and perform the OCLT. Then you will know if you need to shock the pool.
    pool-school/overnight_fc_test
    Jul 2013
    27
    Re: new pool
    I just ordered test kit today could be mon or tues before I get it. You think I might need some bleach so algae don't get out of hand or just wait till test gets here. Thanks
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: new pool
    Do you have any test kit? Even the inexpensive Wal-Mart kit would allow you to get some Chlorine flowing in the that pool.
    I know I use about 1/2-3/4 gallon of 8.25 CL daily with low CYA.
    -- Guy --
    Jul 2013
    27
    Re: new pool
    ok i'll go get one and post results afterwards Thanks
    Jul 2013
    27
    Re: new pool
    fc around 5 cc same ph around 7.6-7.8
    Jul 2013
    27
    Re: new pool
    just estimates
    Jul 2013
    27
    got test kit what next
    MOD Edit: Please keep your posts together on the same issue. Thanks...moderator linen
    Went to walmart as suggested got test kit till the one forum suggested gets here. fc 5 to 6 ph 7.6. Added algae shield this am and pool store said wait 48hr before shocking. I don't trust them after joining here seems like they got me going in circles. pool is still green and cloudy any suggestions? Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: new pool
    You either need to follow the advice here or the pool store, but not both...it does not work. For example, we would have not had you put in a algaecide...and "Algae Sheild" is definitely not one that we recommend (in the rare instances we recommend one). It adds copper to the pool.
    Jul 2013
    27
    Re: new pool
    Thanks, but I added the algae shield before I got on forum and seen post this morning. I've ordered kit suggested and followed instructions to go get one from walmart then posted results. I understand I don't need to listen to both that's why i'm asking you for help. I've done everything suggested here since I got on here this am.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: new pool
    Great...I misunderstood your last post...probably because you started a new topic.
    Hopefully you ordered the tf-100 since Dave (username duraleigh) has fast shipping.
    Did you measure cya with the 6-way drop based HTH kit?
    Jul 2013
    27
    Re: new pool
    that is the one I ordered. I used test strip and cya is maybe 5. its a little darker than 0. after reading through the school i'm thinking its low because I'm vaccuming to waste and adding water back. if I vac to filter 5 to 10 min it starts coming out jets. i'm guessing the algae particals are to small for sand filter. any suggestions thanks again
  20. Back To Top    #20
    Jul 2013
    27
    Re: new pool
    ok started shocking pool early this am. just tested and they are hardness over 250 tc 10 fc 20 ph 8.4 ta 240 cya 30. does it look ok what should I do next?
