Thread: screen on intake
    May 2013
    Arizona
    112
    screen on intake
    We finally got sand sys up but guy switched intake and return we tried today to place eyeball where the screen is (because that used to be in take) however every time we turned it water came pouring out of the exterior of pool where valve is. But without an eyeball to direct water twd new suction area we are not getting the best effect. Anyone know how to switch the intake screen and eyeball inside pool?
    The thru wall skimmer and dedicated vac line get installed tues at eight then create and install pvc waterfall pool water is at 96 degrees we've been in 118-120 for days.
    Also anyone bought these pool lights from walmart where has magnetic stick one inside one out holds together with magnetic. Well don't the magnets are not strong enough for this liners to thick and they are now as waterproof as pkg says. Looking for what others are using as pool lights.?
    Bbb going great water is beautiful
    Re: screen on intake
    Try switching the hoses around, rather than the fittings.
    May 2013
    Arizona
    112
    Can't do that which is y had to reverse them in first place the place where pool is the pump and filter will only fir one way on its snap tray. It has two ways to snap it in but because of where pool was placed can only do it this way so for it to reach had to switch intake and return lines. Suggestions on how to get the eyeball on the return now?
    Jun 2013
    Fallsburg, NY
    258
    You have to swap the entire fitting. The Intex input and output fittings are one piece, you can't remove the screen on the input and replace with the eyeball, you have to remove the entire section that goes through the wall.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    Mine are two pieces that unscrew .. Do yours come apart?
    I just had my intake screen completely stuck from someone not threading it correctly.. It wasn't pretty getting it off :/
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
